All level 8 ecu's are capable of running closed loop.
Whether they do or not is up to the software in the eprom - it must be enabled.
Check the signal of the Oxygen (lambda) sensor. If it is switching between roughly 0.2 and 0.8 volt it's very likely to run closed loop.
