Old Oct 29, 2007 | 08:50 PM
originalcabbie's Avatar
originalcabbie
Try to disconnect the cold start valve at the back of the engine. and give it a run from cold.
You also might want to check the resitance accross the auxiliary air valve which is connected to the cold start functions.
PM me your email and I will forward you an RS Turbo tech document. Which will give you the resistances to look for.
Sounds very strange. does it only do it when cold?
