MF2 is based on an open-architecture design, which means that the unit is freely re-programmable at any time, open to any one who possesses a small screwdriver: no computer interface is necessary! ... working alongside the original ECU, the MF2 controls its own set of injectors, four high-impedance injectors and two low-impedance injectors. It is able to use the signal from the existing sensors, or it can operate independently. 3D-mapping is simple if a load- or pressure- signal is fed into the unit
more here.....
http://www.aquamist.co.uk/cp/mf2/mf2.html
