Old May 6, 2007 | 10:57 AM
James's Avatar
James
no drive with the engine running is one, as when you press the clutch pedel the cylinder is moving towards the clutch, but not actually actuating the clutch as the bearing in between the 2 is now sitting in the bell housing in a load of bits.
It is possible for the clutch centre plate to break but unlikey as this wouldn't break up, thus minimal noise.
always a good idea to change the bearing when changing the clutch.
