Series 2 Rs Turbo starting problem
Old 28-01-2016, 05:09 PM
simonb33
simonb33's Avatar
Default Series 2 Rs Turbo starting problem
Hi all , i have a series 2 rs turbo it has a starting problem i can only get it started if i tap the big paddle / flap on the metering unit if i dont do this it wont start any ideas anyone ?
Old 23-02-2016, 08:30 AM
MrEngineerdat
MrEngineerdat's Avatar
I dont have the real answer for you but i have an alternative... It would seem that something is a bit sticky, i might suggest that maybe the flap doesnt move as you crank it, so its not opening any valves and giving you fuel, and poking it relieves any stickyness from being left over night, making it deliver fuel and start ok, and continue to run. If this is whats going on, you could either set about disassembling for a deep clean, or you could setup a cleverly positioned pipe with a long flexible something or other pushed up it, so you can use this as your pokey finger while still inside the car. This would double as your security mechanism for not being able to start it. I might expect this fault to get worse with time though, if it is indeed sticky. I hope it helps.
Old 23-02-2016, 08:59 AM
simonb33
simonb33's Avatar
Default rs
Thanks , I have tried a different metering unit so the problem lies elsewhere . I think it has an air leak
parso316
Ford Mondeo Including ST
01-04-2018 11:25 AM
Shaunc
Escort Range
08-05-2016 05:24 PM
simonb33
28-01-2016 05:06 PM
mah
Ford Focus (All Models)
25-01-2016 09:00 PM
KAnne
Ford KA
23-01-2016 03:33 PM
Quick Reply: Series 2 Rs Turbo starting problem
