Cosworth AFR gauge readings all over the place
Old 22-09-2015, 05:09 PM
wheelwizardrefurbs
wheelwizardrefurbs's Avatar
Default Cosworth AFR gauge readings all over the place
Cosworth AFR gauge readings all over the place basically if you gradually build up the revs it drives and pulls fine but if you try and give it the beans instantly it will splutter and AFR readings leans out and the goes rich. it also fouls the plugs very thick dry black soot. i have replaced a load of things on it sensors etc it will just not sort itself out. any help would be massivley appreciated! Thanks.
Old 22-09-2015, 05:16 PM
R4N SS
R4N SS's Avatar
have you checked for leaks?
Old 22-09-2015, 05:18 PM
wheelwizardrefurbs
hi mate, as in boost leaks?
Old 22-09-2015, 05:28 PM
Caddyshack
Caddyshack's Avatar
I would be looking for boost leaks and inlet leaks based on the above poster.
Old 22-09-2015, 05:42 PM
wheelwizardrefurbs
there is no boost leaks and sprayed for vacuum/air leaks cant find anything
Old 22-09-2015, 05:45 PM
wheelwizardrefurbs
the car has had NEW
CTS
PHASE
CPS
ROTOR ARM
MAP SENSOR
SPARK PLUGS
FUEL TANK & BOSCH 044 REWIRED.
FUEL LINES
HEAD GASKET
however ive just done a compression test and its reading approx 125 psi that seem low?
original
30-01-2022 08:20 PM
Red_bull
25-08-2015 06:27 PM
mk3 fiesta cosworth
23-08-2015 10:31 AM
14-08-2015 07:29 AM
no1trancefan
Ford Focus ST
07-08-2015 09:21 PM
Quick Reply: Cosworth AFR gauge readings all over the place
