Cossie tickover
Cossie tickover
Hi there just got my cossie motor running in a Mk2 escort but it ticks over at 2.k I havnt got an amal valve on it yet would that cause it?
Thanks Mark
Thanks Mark
Tickover
Hi there i tried unpluging iacv and made no difference then i adjusted tps switch so that it was on .66v closed (the lowest i could get it and i had to swop the wires round) still the same checked for air leaks couldnt find any. Removed iacv and it was stuck half open so poked it and it shut but when you put voltage to it nothing happens so stripped what i could and have left it soaking in wd over the weekend so hopefully its just that.I will be opening another topic later.
Thanks Mark
Thanks Mark
New IACV What AMAL?
New IACV came today and fitted ticks over spot on. Now i need to know what boost control to go for do i just use the standard amal valve or is there a better option?
Russ Payne
25-09-2015 08:29 PM
dange
Ford Mondeo Including ST
23-09-2015 12:11 PM
