Eecv wiring guru's please look
ON THE ROAD AGAIN
Hi , I have a zetec s 2002 that needs to be stripped of all its wiring except wiring to ecu etc
am I right in saying ...
keep all inputs into ecu ...key reader ..key cts, iat cps cas, and so on ...run
a live switched from start panel
neg for sensor grounds
neg for ecu
outputs from ecu :
neg switch wire to fuel pump really
2 neg switch for 2 banks on coil pack switched live through ign switch
anything else I am missing before I do this
neg for ecu
outputs from ecu :
Mark RS
12-10-2015 06:01 AM
