Help with naming a pipe mk2 1.8tdci
have what appears to be a vacuum pipe with a one way flow valve with a nipple which has broken off and seem to supply air to the engine, nipple broke off and ford south africa can not seem to find the part on their system
colin can't seem to supply attachment but if you stand in front of car the said pipe runs up the right hand side of the engine, has a thread on one end which screws in on the fron of the engine, the one direction valve sits near the engine cover and then the pipe runs along the firewall somwhere behind the fuel filter
07-10-2015 12:56 PM
