Cosworth WRC head gasket VS Group.A
Hello to all,i would like to ask about these two gaskets,so which one is suitable for the yb engine with std head bolts?also who from you, use metallic gasket and who group.a and what stage,thanks in advance.
Thanasis
Thanasis
Is it possible to fit WRC or Gp A head Gasket with standard head bolts?
What stage is recommended to install WRC, Gp A or std head gasket?
Am I going to have any issues by fitting WRC head gasket with standard head bolts?
I've got a wrc head gasket with standard bolts for my car that will be running 360-400 hp. If that helps you out.
Have a stud and nut kit but was advised to bin it and use standard bolts
jessie_rs
11
03-06-2019 04:57 PM
