Are there any alarm specialists on here?
I so I need some help.
I have a s2 escort rs turbo, it's fitted with a toad ai606 alarm it all works fine untill it rains quite heavy then my led near ignition is amber and the alarm randomly triggers then when I switch ignition on I get 2 flashes from led.
Once it's dried up outside its fine again.
Hope someone can help as I'm not exactly flavor of the month with the neighbors
Thanks
Thanks
Just check the alarm circuit for water damage, I had this on our sportka, everytime it rained the alarm went off, it turned out to be the alarm plunger switch under the bonnet, when it rained water seemed to run into it, I replaced it but drilled it a drain hole on the mounting bracket, 3 years later its all good.
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
