Removing the airbox from ST170 Help !!!
I've tried removing this and really struggaling to remove the whole air box.
I've managed to remove the 4 screws holding the air filter in, and removing the cable for the MAF sensor.
Is there any screws or bolts that hold the bottom half to the car? I couldn't find any and have been trying to pull it off but don't want to break anything.
Is there a knack to it?
Any help will be greatly appreciated.
Thanks
Thanks
they are a twat to get off mate just needs a good pull there is nothing else holding them on
just 4 small lugs which fit under the air box you wont brake it just pull it
