injector adapters to convert sidefeed hole to take top feeds
as above,
i have this manifold
which uses the ho sandwich plate, but i am wanting to convert the zetec ho sandwich plate to run top feed injectors.
now the holes in the plate are larger and the injectors are too thin to seal, is there anyway to get round this or will i need to find someone to mill some adapters up for this
cheers dave
cheers dave
its a shame to use a differnt inlet a sthis has been made pretty well and i have tapped some vac take offs into it and had the iscv mount welded on what i cut off a xr2i inlet
if i have some adapters milled i will need to run a o ring on the external of the adapters to seal
and the injecters o ring should seal the inner,
if i do have some machined i will be having a lot more made than i need to make it worthwhile
ive got some subaru yellow sidefeeds but these will max out at approx 330hp my engine is fully forged with acls and arps and i want to run a little more power if my turbo allows (t34.63) plus i want some scope for later improvement
cheers dave
cheers dave
09-10-2015 07:38 PM
lee2cossies
26-08-2015 10:04 PM
