vauxhall combo van problem
Old 19-08-2012, 01:49 PM
  #41
mechanic28
mechanic28's Avatar
its under the vehicle around the gear linkage a little black tube
Old 20-08-2012, 02:22 PM
  #42
northend
northend's Avatar
Default Vauxhall Combo van problem
BINGO. After 2 years of wet carpets, got under the van this afternoon, found the little rubber drain pipe exactly where described, poked in a long screwdriver and was thoroughly wetted by lovely pure water. It just pays to describe your vehicle correctly otherwise I would still be looking at the brake servo, drainage flaps etc. Thanks so much for your help.
John R
Old 16-10-2014, 07:57 PM
  #43
Loveplug
Loveplug's Avatar
Originally Posted by botters
he means it will let rain water in mate
mine was the steering column behind the pedals the bulk head didn't have a seal around the steering column
Old 22-02-2017, 06:34 PM
  #44
Chris Warren
Chris Warren's Avatar
Default Vauxhall combo 1.3 2008 rain getting in
Hi I have a 2008 combo van and rain is getting in through the passenger footwell heater any ideas how to fix this ?
Old 23-02-2017, 07:45 PM
  #45
stevieturbo
C**t
stevieturbo's Avatar
Locate the leak and fix it lol.
Some say the fuse box seal can leak, others say a build up of leaves or crap in and around the battery/fuse box area can cause leaks too.
But really you've the vehicle there, you need to look about and find out where the water is coming from on yours
Old 23-02-2017, 09:30 PM
  #46
ray barker
ray barker's Avatar
Originally Posted by MJ_RST
Seat yins will be either T40 or T50's
Common on the corsa c's, they leak from the brake servo panel. under the bonnet, look at the black panel, should have sealer round it, but it will prob have cracked.
learn sumut new 2day yins i didnt no that
markeh
Ford Focus Diesel
11-04-2016 02:15 PM
Flatlinedan
18-09-2015 12:41 PM
benw456
16-09-2015 05:27 PM
S3an
13
13-09-2015 10:01 AM
Bighandsuk
02-09-2015 05:23 PM
Quick Reply: vauxhall combo van problem
