| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Technical help Q & A Got A technical problem with you car? Keep it in here where the techies hang out and we will try to solve it for you!! |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
H71 CNX
#2 |
![]() BANNED |
The C5T2 is a cat 21 alarm, so why not use the immobiliser circuit in this, if used with the sigma it may be that it is in fact a C4T, as this is a cat 2:1 upgrade.
Either way odd that you should get flashes like this, the 4 flashes is boot/bonnet though. I would disconnect battery again, then close all doors/boot, hold down the bonnet pin switch when reconnecting the battery, and see if that helps, as they can play silly buggers if they forget polarity, which they shouldn't but occasionally do. A common false alarm on fords is the mercury switch used in the tailgates of some cars, to activate the boot light, but is only really on a hot day as the mercury expands and causes the contacts inside the switch to be joined and so set alarm off. tabetha |
#3 |
H71 CNX
Not a bad idea to use the integrated imobiliser in the Toad tabetha. Unfortunately, my knowledge of car electrical syatems is rather limited and I wouldn't know where to start.
Any ideas about how to reset the Sigma imobiliser? |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Toad Cat 1 C5T2 problems... | Fezza | Technical help Q & A | 1 | 01-07-2009 07:05 PM |
| toad ai606 alarm problems | 155lee | Technical help Q & A | 12 | 15-12-2008 07:19 AM |
| Toad C5T2 Immobiliser Module | MMartin | Alloy wheels and ICE for sale | 1 | 02-01-2007 05:41 PM |
| sigma alarm keyfobs | magic randy | General Car Related Discussion. | 1 | 19-12-2004 06:26 PM |
| SIGMA ALARM | townie9371 | General Car Related Discussion. | 4 | 27-10-2004 08:53 PM |
