PassionFord
Go Back   PassionFord > Tuning, FAQ & Post Archive's. > Technical help Q & A
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 18-08-2009, 06:48 PM   #1
Matt-G
Matt-G's Avatar
Trader Score: (0)
Matt-G is on a distinguished road
Default Mondeo 1.8td noisy tappets
Hi All,
The list of faults with the ramshackle mondeo is getting smaller at last... New cambelt(s) are on, new alternator has sorted the fluctuating lights and the new water pump seems to have sorted the temperature. Having changed the oil the tappets seem to be quite a bit noisier than they were. Do you think this could be that the old oil was very sludgey so keeping them quiet or something more sinister?
Thanks in advance,
Matt
Matt-G is offline   Reply With Quote
Old 19-08-2009, 07:51 AM   #2
Matt-G
Matt-G's Avatar
Trader Score: (0)
I guess what this really needs is the shims sorting out however I don't have time to do it. Unfortunateley it only started after the oil change yesterday.. Are their any additives anyone would reccomend or should I just leave it as is?
Any help greatly appreciated
Old 21-08-2009, 08:44 AM   #3
Trader Score: (0)
tabetha will become famous soon enough
Only thing you can do is shim them when you have time, most are never done, you can always check them to get your clearances known, then put together, not much work to do work out your shims, bearing in mind it's perfectly safe to do swappsies on these, then buy your shims, about £3 each that you need, very common size diameter then just swap over later.
tabetha is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Noisy tappets after high revs rapidcossie General Car Related Discussion. 30 22-07-2008 10:52 PM
Mondeo 1.8td coolant Matt J General Car Related Discussion. 0 21-09-2007 08:11 PM
MK1 Mondeo 1.8TD LX Mondi16vZetec General Car Related Discussion. 2 03-01-2006 07:12 AM
s2 noisy tappets. due to low oil pressure? skeld Technical help Q & A 4 09-08-2005 09:48 AM
Noisy Cossie Tappets on start up... Just on Boost Technical help Q & A 2 23-07-2005 06:14 PM
