Sapphire Cosworth 2wd - Coolant & Fuel Warning Lights
I've never seen the Low Coolant or the Low Fuel Warning lights lit up before
til the other day (after it threw it down with rain as it happens)
Low Coolant is constant
Low Fuel Warning is intermitant...... lit up for a while the other day when I had half a tank
any idea's ???
any idea's ???
I can have a look at some diagrams over the weekend, but this is powered off fuse 22, but there won't be an issue there as it wouldn't light up at all if it wasn't getting any power. I suspect it will be an earth related problem, common to both of these lights. The power supply for these bulbs is common to the rpm, coolant guage/petrol guage/dash warning lights/illumination test lights in centre of dash, if there are all working ok then the problem is elsewhere.
