PassionFord
Go Back   PassionFord > Tuning, FAQ & Post Archive's. > Technical help Q & A
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 21-07-2009, 09:17 PM   #1
alex&nath
Trader Score: (0)
alex&nath is on a distinguished road
Default 1.3 Endura-E Engine oil leak through air box
Hello Peeps,
I need a little help. My little fiesta has been using quite a bit of oil, been topping up with a 1 litre bottle every so often.
However the other day I noticed quite alot of oil on the floor, after 5 minutes of investigation today I found the air filter box had lots of oil in it. It seems to be coming from the pipe that comes off the filler cap on the rocker cover.
Anyone have ideas what might be causing it???
Am I gonna have to do the valve stem seals? Can I do this with the head in place or does it need to come off?
Nath
alex&nath is online now   Reply With Quote
Old 21-07-2009, 09:43 PM   #2
OldDan
OldDan's Avatar
Trader Score: (0)
OldDan is an unknown quantity at this point
Send a message via MSN to OldDan
Sounds like valve stem seals yes! That is the oil breather you are talking about.
I'd personally do it with the head off the car.
Also - it could also be due to maybe the block breather being blocked and causing blowby? Maybe.
__________________
"On that occasion I said to him 'why do you do a tackle like that?' And he said 'because I don't like you'.
Patrice Evra speaking of tussles with Super Kevin Davies.
OldDan is online now   Reply With Quote
Old 22-07-2009, 12:16 PM   #3
alex&nath
Trader Score: (0)
Quote:
I assume they are the other pipes that come from down the back of the block and join up with the oil beather?
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Oil leak on new engine.. Mk2_2dr_2L_Escy Ford Sierra / Sapphire / RS500 Cosworth 1 07-02-2007 12:02 PM
OIL IN AIR BOX Matt Baxter Ford Sierra / Sapphire / RS500 Cosworth 12 02-03-2006 08:33 PM
major oil leak coming form under tray beneath g-box Big D Ford Escort RS Turbo 11 08-05-2005 11:37 PM
RST Engine Oil Leak John Laverick General Car Related Discussion. 9 04-03-2005 02:44 PM
please help.low oil pressure and air leak starturbo Technical help Q & A 0 03-06-2004 07:59 PM
