Rwd cossie powered focus project..
#122
Had a few hours today..
Finished off the reflect-a-gold..
Steering rack in..
Have had to order longer rose joints for both the track control arms and the track rod ends as they are slighty different to standard cossy stuff. They should be here by friday hopefully.
Picked up last bits from vapour blasting..
Just sump to fit which il be doing tomoz
Few more bits turnt up this week also..
Setrab oil cooler and brackets..
And Injector dynamics id1000 injectors..
really looking forward to getting the engine back in its hole now!!
Steering rack in..
#125
Steering rack in..
Steering rack in..
Mark
#126
They may well be the same mate, they are defo jap size as they were intended for a 200sx running top feeds on a greddy inlet/fuel rail.
Glad you have commented as was going to ring you, can I remove the top cap totally or will it affect the flow? If not I do have a rail which will fit, failing that I can get new top caps...
#127
Mark
#129
Couple more hours spent down the unit today..
Old sump off..
Had a spare pick up pipe as well, just as well really as the one was blocked, all sorts of horrible shit in it!! Only two of the jets were firing so pretty glad iv decided to do this..
New pick up, sump, cometic gasket and new bolts fitted
As the car stands at mo
Engine and box ready to go in tomoz..
Dropped my coilovers down to gaz in basildon yesterday for a refurb, they are also going to revalve them for more track work in mind as well as replace bearings, seals, re zinc bodies and coat springs etc, they reckon they will basically be a brand new set of coilies with better valves
Also dropped these off to be refurbed..
Undecided whether to keep them grey or go a standard looking alloy silver, whats peoples thoughts??
Few bits turnt up also (again) haha
The longer rose joints for track control arms and longer bodies and joints for track rod ends..
Inlet nuts and studs, exhaust studs..
And a dirt/dust plate for the bellhousing/block..
More updates tomoz once the engine is in its home
Old sump off..
#130
Had a day in the car yesterday, heres what happened
New exhaust and inlet studs fitted..
Exhaust and inlet manis both fitted..
Gearbox fitted..
Something i had to sort before getting the engine and box back in was this..
Just part of the car that was half heartedly done in the beggining and realy got on my tits!!
Quick play with a grinder and power file...
Much better
Then the engine and box went in..
Slam panel and crash bar back on, having this all removeable is so handy with engine removal/fitting. Can loterally wheel the two out on a jack!!!
Then i got the compression struts, track control arms, hubs and rod ends fitted (needs locking nuts on rod ends still)
I did clean up the aston martin brembo front brakes, although im thinking of selling these in favour for either alcons or AP's..
Mitch
Gearbox fitted..
Much better
Mitch
Focosmitch (25-11-2014)
#135
Love the attention to detail on this.. Just curious, seeing it's an A1 car, is it the white one they built? Was always in performance ford years ago?
How's your little boy doing, growing fast?!
#136
Cheers stu!!
No mate not the same car, alot of people have been getting confused with it also, far as i know this has always been blue. If you go google images, they are differnt registrations etc.
Yeah he is really good thanks mate, changing everyday! Sleeping well of a night time which is always a good thing!!
#138
Cheers stu!!
Sleeping through overnight has to be good!!
Focosmitch (26-11-2014)
#143
#145
Top job mate bangin focus
#152
very nice how much are they mate? Whats your target for power?
#158
Nice look forward to seeing it go together and yours jay. Can i ask you mate how do the wheels sit using the cossie beam ect do they run spacers im trying to work out how mine will sit with 4x4 running gear as want to run 5 stud hub conv but cant really work anythibg out until its all bolted up
Focosmitch (28-11-2014)
#160
With regard to wheels, they sit lovely in the arches mate, all depends on offset though doesn't it. All about the offset
