Mondeo RWD
Old 03-01-2014, 09:47 PM
  #161
markobcars
markobcars's Avatar
BIG THANKS to everyone supporting this project!! I'm glad You like it!!
I really don't know what to say about the fuel tank donation... It would be a great help to just find one and send it to me,I'll pay for everything in advance if needed!!
I will need some help in buying a lot of small plastic/rubber bits and fittings for the body because we don't have this detailed parts here in Croatia and that would be a great contribution from anyone who wants to help me finish this dream project...
Regards
Marko
Old 04-01-2014, 06:23 PM
  #162
markobcars
markobcars's Avatar
Update for today...
While I am waiting for the parts from water jet cutting I made threaded inserts for gearbox mounting and welded them on the chassis. I also reinforced the mount points with a beam that disperses the load on a grater surface area...
Gearbox mount will be slotted so correct gearbox and engine position can be adjusted.
Old 05-01-2014, 12:30 PM
  #163
luke89
Team HOTHOT!
luke89's Avatar
great project and done really well bud , hats off to you !
Old 05-01-2014, 02:15 PM
  #164
karl mcghee
karl mcghee's Avatar
one work quality workmanship a lot of thought going into this time and patience
Old 05-01-2014, 03:18 PM
  #165
Good progress.
Old 05-01-2014, 05:40 PM
  #166
markobcars
markobcars's Avatar
Thanks guys!!
Today I started TIG welding the front subframe but It is not finished yet...
Steering rack is lifted 10mm to make room for rack gaiters.
Old 08-01-2014, 07:39 AM
  #167
pugford55
pugford55's Avatar
Thumbs up
Excellent work mate, very impressed..
Old 08-01-2014, 09:59 AM
  #168
studabear
studabear's Avatar
Big respect for this build, really enjoyed having a read through the thread.
Old 08-01-2014, 05:22 PM
  #169
whizzisat114
whizzisat114's Avatar
Have you worked out what front hubs your using yet?
sorry if youve already mentioned it.
Have you tried the gearbox in and checked for ground clearence as it look like its going to be close to the flooe with how low the mount is.
Old 08-01-2014, 05:57 PM
  #170
markobcars
markobcars's Avatar
Thanks everyone!!
Old 08-01-2014, 06:07 PM
  #171
markobcars
markobcars's Avatar
Front hubs are going to be the Mondeo ones switched from left to right with adapters for rod ends that will be adjustable/exchangeable to improve Ackerman geometry...
The standard gearbox mount used here is just a base point for a new mount... It is too low,You are correct and I'll make a new one or modify this one...
Front subframe is positioned in line with the lowest floor beams and the gearbox mount will follow that plane/line...
Old 08-01-2014, 06:41 PM
  #172
whizzisat114
What steering rack are you using?
Raising the steering rack will affect your bump steer wont it?
Old 08-01-2014, 07:01 PM
  #173
markobcars
markobcars's Avatar
Steering rack is a Sierra rack with shortened Mondeo tie rods!
Mondeo steering arms on hubs are positioned much higher than sierra steering arms so I have to raise the rack and lower a tie rod mounting point on the Mondeo steering arms with aforementioned adapters.With this mod I'll get the tie rods in line with the steering rack so bump steer is minimal!
It will be a street driven car but suspension travel will be much smaller than standard mondeo suspension and that will also improve bump steer...
The Sierra rack is wider than Mondeo one so I shortened the tie rods and that is not a good thing for bump steer but on a short suspension travel it will work fine.
Old 08-01-2014, 07:19 PM
  #174
markobcars
markobcars's Avatar
Also when looking deeper into the bump steer/roll steer geometry design the Sierra rack is in fact more suitable for neutral bump steer geometry because tie rod length is closer to lower A arm length(from pivot point to ball joint) than Mondeo standard length tie rods.
That means for any suspension travel both A-arm and tie rod will make the same radius circle and toe in/out will be unchanged.
Old 08-01-2014, 07:28 PM
  #175
whizzisat114
Good work and I look forward to seeing your progress
David
Old 08-01-2014, 07:30 PM
  #176
markobcars
markobcars's Avatar
Thanks!! I can't wait to get it on the road...
Old 08-01-2014, 07:59 PM
  #177
rwd_fiesta
rwd_fiesta's Avatar
Fantastic project. Very original. Your attention to detail is great.
I do have one point to make. You say you are reversing the Mondeo struts. Be careful as I believe this will adversely affect the ackermann effect because the steering arms will be angled in the wrong direction for a steering rack ahead of the front axle line. Your easiest solution maybe to simply use Sierra struts. Best of luck.
Old 08-01-2014, 08:23 PM
  #178
markobcars
markobcars's Avatar
Thanks!!
I am aware of the ackerman change with reversed Mondeo hubs and I'll correct the geometry with the adapters to get the first setup to "true" ackerman and than I'll work from there...
I'll try the Sierra hubs but I think that they are not suitable for Mondeo geometry,they induce too much negative camber when used with standard top and bottom mount points.
Old 08-01-2014, 09:04 PM
  #179
markobcars
markobcars's Avatar
I made this ackerman/angle correction adapters for drift E36 race car...
Something similar will be made for the Mondeo...
[/url]
[/url]
[/url]
Old 08-01-2014, 09:30 PM
  #180
rwd_fiesta
rwd_fiesta's Avatar
You are obviously on the case so I'll keep quiet. Just out of interest, if you need to pursue the Sierra route, you can use the 4x4 hubs with the
Bilstein 1.5 neg camber strut casings turned through 180 degrees to give positive camber. This could help you if you get stuck.
Old 08-01-2014, 09:56 PM
  #181
markobcars
markobcars's Avatar
Don't get me wrong! I am opened to advices but there is so much to think about and I am not in the workshop so it is difficult to know what might work... And there are so many options... I'll check again the Sierra hubs but iirc they don't fit straight in... Thank You for the info!!
Old 10-01-2014, 08:16 PM
  #182
markobcars
markobcars's Avatar
Front subframe is 99% welded and I removed all excess metal from old steering rack mount/bridge.
The subframes are fitted and also the engine,differential and gearbox so I can reconstruct the gearbox tunnel,prop shaft bearing mount and adjust engine and differential angles.
Prop shaft will need to be lengthened 110mm.
I will make a completely new gearbox mount...
Possible sway bar position...
Old 11-01-2014, 03:45 PM
  #183
Cool progress mate.Top work.
Old 11-01-2014, 04:25 PM
  #184
dojj
Resident Wrestling Legend
dojj's Avatar
get a prop from a granada as the front bit is longer and that way you can shorten it rather than lengthen the sierra one
Old 11-01-2014, 08:22 PM
  #185
markobcars
markobcars's Avatar
I was looking for a granada prop shaft for 3 days on local scrapyards but those cars are hard to find these days so today I made a new prop shaft with seamless tubing.
I have to say that Ford original prop shafts are not that good... They are made from thin seamed tubing and they have a run out of aprox 2mm from end to end... I tested 2 prop shafts...
Mine has a run out of 0.05mm!! I welded it with TIG on a lathe so it didn't pull anywhere when welding...
Old 11-01-2014, 08:33 PM
  #186
Mk4 Rick
Mk4 Rick's Avatar
That's pure skillage
Old 11-01-2014, 08:44 PM
  #187
markobcars
markobcars's Avatar
Thanks
Old 11-01-2014, 09:59 PM
  #188
dojj
dojj's Avatar
and you are obviously going to have it balanced yes
not that you won't, but just making sure you will, because theres nothing else that says "can i have some new ankles please" than a broken prop
Old 11-01-2014, 11:05 PM
  #189
markobcars
markobcars's Avatar
Yes I'll get it balanced after I fill it with polyurethane foam for noise reduction... I have to send it 270km away in another town for balancing!!
I've shit my pants once my prop shaft broke!! luckily it was at 60km/h... It left 30mm deep scratch marks in the pavement before it broke away completely!!
Old 12-01-2014, 11:02 AM
  #190
den_band
den_band's Avatar
Hi Marko,
nice project and professional build!
I have a Mondeo Cosworth RWD as well, and use it for Rallycross trackdays.
It's a Mondeo body on a Sierra floor, so entire Cosworth suspension fits rather easy.
Since the rear wheels had to much camber, I made camber and toe adjustable at the rear axle (front side made fully adjustable as well).
Together with the shell, I have the moulds to produce fibreglass bodypanels. They come from the MKII successor of the Karcher Mondeo MkI which was posted earlier in this topic by Mondi-DZK.
Some pics:
https://skydrive.live.com/redir?resi...=folder%2c.JPG
Success with your project!
Old 12-01-2014, 12:44 PM
  #191
pugford55
pugford55's Avatar
Originally Posted by den_band
Hi Marko,
Some pics:
Sorry to butt in.. Will these f/glass panels fit a Mondeo Eurocar mk2 as the shp kits
Thanks
Old 12-01-2014, 05:37 PM
  #192
den_band
den_band's Avatar
@pugford55: I'm not sure. My panels fit the standard Mondeo MkII shell. Only front and rear wheelarches are wider...
Old 12-01-2014, 05:58 PM
  #193
markobcars
markobcars's Avatar
Hi Marko,
Some pics:
Hi!! Thank You!! I like your project very much!! I wish I could build a race car... My nearest race track is 300+ km away so building one is out of the question...
I'll have to make the rear beam fully adjustable if I get into camber/toe problems...
Please send me a PM if you can produce the fiberglass panels or you are interested in selling the moulds!!
Cheers!
Old 12-01-2014, 06:11 PM
  #194
markobcars
markobcars's Avatar
I wasn't happy with how the welds came out on the prop shaft... also when I positioned the prop shaft bearing it could be some 15mm longer so I made another one...
Pulse TIG welded to control heat input.
Old 14-01-2014, 04:13 PM
  #195
fury556
ST170
fury556's Avatar
Awesome build!
And that's some serious welding porn!
Old 15-01-2014, 12:58 PM
  #196
mentalasanything
mentalasanything's Avatar
Originally Posted by markobcars
I'm Not Crazy. My Mother Had Me Tested!
I think you need re-testing
Seriously enjoyed reading the thread and that fab work is amazing.
I am intrigued by the fact you've made your own ECU. It's something I've often pondered with the cheap PIC's you can buy these days. Look forward to seeing that.
Keep up the good work!
Lee
Old 17-01-2014, 04:14 PM
  #197
markobcars
markobcars's Avatar
Thanks everybody!!
I have a BIG problem finding the plugs for silvertop/blacktop zetec TURBO engines!!
I would like to have a heat grade 6 or grade 7 NGK plugs like PLTR6A-10G but these are hard to get here in Croatia...
Does anyone have some suggestion on the plug selection from manufacturers other than NGK??
Old 17-01-2014, 04:24 PM
  #198
fury556
ST170
fury556's Avatar
I'm not sure what they used, but can you get standard Focus RS plugs? I assume they were Motocraft made or something! If not, I guess V*uxhall turbo plugs should do as well?
Old 17-01-2014, 05:43 PM
  #199
clairendave
Dave not Claire.
clairendave's Avatar
I had the plug seat modified in my head to run different plugs. i seem to remember they were escort cosworth, but it was too long ago to be sure.
Old 17-01-2014, 06:28 PM
  #200
Mk4 Rick
Mk4 Rick's Avatar
You can use focus rs plugs there is also a thread some where a zetec spark plug holes were modified to take cossy plugs
Quick Reply: Mondeo RWD
