not goin to mad jon, engine is ready to go in, shud be good for 400ish hp? when set up, post pic in a mo, got some mk2 focus rs front n rear seats mite put them in instead of the original leather.
loooooove this one!!!though not a fan of changin color on a car....this would always kinda be a mallard car...in some way....but as long as its a full inside out respray....i guess it doesnt matter .
anyways...looks aaaawesome mate!cheers from norway
cheers mike, same to you pal, yours look the dogs mate, bet its about finished now init, did you get the stickers on the prop, g/box, diffs, shafts etc from fords or did you get um made up?
yeah I no what you mean mate but it wanted a fresh coat of paint, so decided to go white, nearly did it gloss black but changed mind when it was in the booth not to keen on mallard anyway.
Thanks mate, yeah it's around 80% done, waiting on bits coming and I can crack on again.
It'll be next year when it's running, big money parts to buy next and I'm going on holiday next month.
small update folks, painted the fuel tank at weekend, got it fitted today, built the hubs, diffs, and rear shafts up just waiting for trailing arm bushes then the rear beam can go in.
small update folks, fitted the rear beam and brakes over the weekend, started the hyd clutch convertion, done the gearbox, bulk head and pedal box next, using landrover defender master and slave cylinders,
