focos 4x4 its home
Old 28-10-2012, 08:19 PM
  #401
dingla rs
dingla rs's Avatar
Hope so mate longer than the engine will lol
Old 28-10-2012, 08:32 PM
  #402
graham c
graham c's Avatar
wot block you on 200 ?
Old 28-10-2012, 10:05 PM
  #403
dingla rs
dingla rs's Avatar
205;( lol
Old 28-10-2012, 10:25 PM
  #404
graham c
graham c's Avatar
I've will last for a bit you just carnt long stud them
Old 28-10-2012, 11:31 PM
  #405
Minirotty
Lucifer II - 666
Minirotty's Avatar
Looking good bud.
Old 30-10-2012, 06:54 PM
  #406
dingla rs
dingla rs's Avatar
Originally Posted by Minirotty
Looking good bud.
Cheers mate
Old 30-10-2012, 06:56 PM
  #407
dingla rs
dingla rs's Avatar
It's on stud an nuts ,will source a 200 block
After a gear box
Old 31-10-2012, 10:29 AM
  #408
fezzajsy
fezzajsy's Avatar
looking good
Old 31-10-2012, 05:49 PM
  #409
dingla rs
dingla rs's Avatar
Originally Posted by fezzajsy
looking good
Cheers mate , I'm to busy with 3 of my friends
Car at the mo but hopefully they will return the
Favours over the Xmas hols
Old 12-11-2012, 01:34 PM
  #410
dingla rs
dingla rs's Avatar
no real update on the car but been ordering parts off matt lewis and msd
4x4 plugs
filter
2wd oil feed an filter
engine sensor kit
drop braket for alternator
boost hoses in blue
off matt lewis
got some proper bell hosing bolts coming off carparts express an diff oils
msd the wasted spark driver
also fuel lines more brake line finish passenger side caliper
struggling with oil return pipe to sump but will keep looking
few other small things aswell engine is coming back out to mod tunnel
next then will all go togther over exmas hols
Old 12-11-2012, 01:38 PM
  #411
dingla rs
dingla rs's Avatar
will order some pipe finish screamer pipe aswell
Old 12-11-2012, 01:43 PM
  #412
whizzisat114
whizzisat114's Avatar
Looking good Andy
Can you run bov other way round as it looks like the screamer pipe will be close to flitch
Old 12-11-2012, 02:05 PM
  #413
Mr C
Mr C's Avatar
Originally Posted by dingla rs
had a play on me brothers new lathe other day ,so im ready when turbo turns back up to make a turbo damper for it
I meant the Track Rod End spacers above, what length are they? They look better than my solution of a long bolt. Cheers
Old 12-11-2012, 02:22 PM
  #414
dingla rs
dingla rs's Avatar
Originally Posted by whizzisat114
Looking good Andy
just had a play see what it looked like mate i need find some were order bends ect for pipe work
il get some measurements later mate
Old 13-11-2012, 09:42 PM
  #415
dingla rs
dingla rs's Avatar
had a big step back words to nite the loysport crew were round take a few things off car some how manged to lose two important bolts drunken cunts lol
anyway engine back out an big hole in tunnel wasnt happy with how close box was ,means iv got repaint floor an remake gear box mout cradle
Old 13-11-2012, 10:05 PM
  #416
whizzisat114
Bloody he'll Dingla you need Velcro on your engine mounts lol.
What bolts you lost?
Old 13-11-2012, 10:07 PM
  #417
whizzisat114
Reference the turbo return .
If you send me template of turbo and spec of pipe I'll knock you one up after my Xmas dinner
Old 13-11-2012, 10:13 PM
  #418
dingla rs
dingla rs's Avatar
the 3 bolts that hold prop on they lost one fook nose were
its a t4 oil return im strugling find i mite use braided hose
Old 14-11-2012, 12:54 PM
  #419
dingla rs
dingla rs's Avatar
^^ cheers mate .my wasted spark drive turned up no instructions tho will be going down with ecu to my brummie friend dave to sort out
Old 14-11-2012, 02:05 PM
  #420
COLEYST200
COLEYST200's Avatar
Dave dose not no wot he is doing with wiring he is colour blind . Only kidding dave loves his wirring . Dave or me can do this for you Andy so take your pick . Iv sent off for you phone case as well
Old 14-11-2012, 03:34 PM
  #421
dingla rs
dingla rs's Avatar
ur not wrong there ian he will never live down cutting my indicators out of my wiring loom already asked dave ian im sure you will be round his anyway the cover are good altho i dont use mine its just on side lol
Old 14-11-2012, 03:37 PM
  #422
dingla rs
dingla rs's Avatar
hole welded up used me mates welder god its got a worse stutter than my mate spencer will bring airline home and me guns an get it painted few things to do while engine out
Old 14-11-2012, 05:26 PM
  #423
whizzisat114
You cheeky twat
i think if you plug in a none focus rs headlight youll find the indicators work
just dont get plugging in your rs bumper till ive been back up
Old 14-11-2012, 07:28 PM
  #424
dingla rs
dingla rs's Avatar
just to paint now when sprayable sealer is bit harder
Old 14-11-2012, 07:30 PM
  #425
dingla rs
dingla rs's Avatar
You cheeky twat
i just like giving you grief for it dave
Old 14-11-2012, 07:35 PM
  #426
Richie.
aka Turbosailorboy
Richie.'s Avatar
Location: Under the water.... .......in a nuclear submarine
What sort of sealer is that Andy?
Old 14-11-2012, 07:45 PM
  #427
dingla rs
dingla rs's Avatar
sprayable seam sealer richie special gun for it what they use in factory
http://www.ebay.co.uk/itm/FUSOR-312-...item35bdc73dd4
this like mine didnt come from states tho .altho there are loads of makes wurth an 3m do them mate
any sealer gos in it i use this
http://www.ebay.co.uk/itm/SPRAYABLE-...item4a8529f24c
Old 14-11-2012, 08:20 PM
  #428
graham c
graham c's Avatar
good stuff,but not a fan of spayable sealer myself. get some paint on it so you can get it back in
Old 14-11-2012, 08:43 PM
  #429
dingla rs
dingla rs's Avatar
its mainly to give factory finish on cars i doing for mates will be back in soon
Old 15-11-2012, 02:04 AM
  #430
COLEYST200
COLEYST200's Avatar
So I take it Andy you have had to cut the tunle out as the gear box was hitting it . I did that mod right at the beginning of my build when we did a mock up with a gear box and bock
Old 15-11-2012, 06:35 AM
  #431
dingla rs
dingla rs's Avatar
Tunnel was heated up an beat out had engine box
In last year an beat it some more just going lift gear box up 15 mm an
Drop engine down Ian so it left box very tite to
The tunnel , I need drop engine out for couple
Things anyway 😃
Old 15-11-2012, 02:32 PM
  #432
dingla rs
dingla rs's Avatar
Originally Posted by Di8ed3er7ich5
i need some 17mm spacers for rear end but will use the welded washers for now
what is it ur spacing out mate ?
Old 15-11-2012, 02:34 PM
  #433
dingla rs
dingla rs's Avatar
breather turned up ,and some studs for front diff cheers dave
Old 15-11-2012, 04:41 PM
  #434
Cool Parts andy.They sealer spray looks good.
Old 15-11-2012, 05:44 PM
  #435
dingla rs
dingla rs's Avatar
cheers glen to be onist im sick the damed thing already shame none my mates own cossies be so much easier
can anyone tell me if the water pump pully is rite ? and can i run the 2wd powersteering set up ,alternator will be on drop braket
Old 15-11-2012, 05:57 PM
  #436
whizzisat114
Alternator pulleys a 4x4 one you need 2wd pulley on alternator
Old 15-11-2012, 06:00 PM
  #437
whizzisat114
Sorry m8 :-(
Looks like you need bottom pulley and alternator pulley off a 2wd.
I think the multi rib pulley set up is 4x4
Old 15-11-2012, 06:04 PM
  #438
andy escos
andy escos's Avatar
the thing is Dave that the alternator pulley matches the crank pulley so he needs a 4x4 multi v water pump pulley he might also need the large 4x4 /escort alternator power steering pump bracket & not the drop bracket .
Old 15-11-2012, 06:06 PM
  #439
dingla rs
dingla rs's Avatar
dave dont the bottom pully drive power steering pump,and a sierra 4x4 water pump pully is ribbed? this escort cossie one as far as i can make out may be wrong
Old 15-11-2012, 06:19 PM
  #440
andy escos
andy escos's Avatar
the ribbed part of bottom pulley drives power steering ,alternator& water pump the extra v on the front of crank is for air con .
this is a escort cosworth set up but i machined off the extra v for clearance.
Quick Reply: focos 4x4 its home
