what paint for xr2
If you are planning on painting your car, then i would personally use 2 pack paint, base and then clear, its a lot more forgiving for a diy job, celu paint shrinks back so it needs loads of coats for it to look pro.
Alternatively if this is your first attempt, you could save yourself £££ by prepping the car yourself, and then giving it to a pro to paint, this is what i usually do.
Does not really matter what paint is on the car, i am assuming you are planning on spraying the whole car with filler primer once the existing paintwork has been keyed with sandpaper..
Thanks for the advice ive done all the prep work under the plastic skits as it was a state and am gona give it ago my self. The car still has origonal paint is this 2 pack or cellulose at that age?
07-10-2015 12:56 PM
rsguy
44
29-09-2015 03:29 PM
