Diamond White 1986 Ford Fiesta XR2
When I first got it, it looked like this bit sorry for its self but not too bad shape.
but if you go looking for trouble your gonna find it.
and so i took the car off the road and starting making headway on restoring it to the best of my abilities.
The original idea was to leave the n/a cvh engine with a couple of changing to make it bit of power full.
The carb plus ported and polished head, a rs1600i cam and a 4 branch but once i took the head of the engine i discovered a very worn bottom end the lip to the bore was massive. After i had drop the bottom end out of the car i left it outside in the rain and only 1 or the bores managed to hold any water.
So engine is slightly forgotten about for the moment as i dont have the shell sorted yet.
and i think that pretty much bring it up to date. Still working on it as much as i can. Hoping to have it finished by august at the lastest so i can drive it during the summer before taking it off the road next winter to get a decent turbo lump of some sort. The only thing that can really hold me up at the moment is money.
Look's a nice project
Do your self a favour though and get rid of the gasless wire and start running gas through the welder it will transform your weld's
It did with my clarke welder
Yer i have got the gas now. Is a massive difference! The gas doesnt last that long tho.
No your right there most of my m8's run a midi co2 bottle from ocal paint suppliers probably set you back Ł40 first then Ł15 for a change over bottle
Do you have a jaywell's paints near you?
vdun01
Ford Fiesta
05-10-2017 08:14 AM
