Can you please PM me some info on your wheels as im thinking about getting the same ones for my 3dr i need to now wot sizes front / back / off sets as they look spot on and are they 4 stud or 5 stud . Thanks for any help you can put my way
Can you please PM me some info on your wheels as im thinking about getting the same ones for my 3dr i need to now wot sizes front / back / off sets as they look spot on and are they 4 stud or 5 stud . Thanks for any help you can put my way[/Q
Toof the car out for a drive today very different drive to before, but felt good. Just trying to dodge all the potholes now as theres not much tyre to protect the wheels. Corners like its on rails now ive set the coilovers to solid, glad i didnt go any bigger on the tyres though because theres not alot of room under there now!!!!
iv just put the same wheels on my 3dr but would not go over my 330"rotors and brembo's so iv had to fit with spaces...look mint tho 225/35/17 on front and 245/35/17 on rear
spec is 4x4 engine with mild ported head 2wd ex manifold t34.55 grey injecters 30psi peck 28 psi held 500 intercooler collings chip 3 bar map 044 pump all engine bolts studs are arp's ap 4 paddle cluch no springs 4x4 inlet with 20mm spacer
After a recent trip to a friends in the car noticed some oil under the car, on closer inspection i found the cam bearing had collapsed and taken the oil seal with it.
So after stripping it down and replacing the bearings seals and spacers ect
Replaced all the belts and tensioners ect new oil and filter and a magnetic oil sump plug from motorsport developements
Going to rewrap the exhaust as the old heat wrap has started to come off, and also might have a go at making a surround for the air filter.
those calibre wheels look awesome and good to hear they can clear 330mm discs with brembos as thats what im running and didnt buy these wheels as i didnt think they would fit
As far as i know they dont clear 330s without some big spacers
