ST170 mk1 fiesta crossmember update 2/9/15
Old 22-10-2013, 04:45 PM
  #201
Timo.K
Timo.K's Avatar
Yes, standard cams.
Old 22-10-2013, 04:58 PM
  #202
XR2
XR2's Avatar
And I bet your ECU won't support VCT?
IIRC standard Zetec cams will fit the ST170 head, for you power figures I'd go at least for some fast road ones.
Old 22-10-2013, 07:35 PM
  #203
Timo.K
Timo.K's Avatar
The ECU does support VVT, although only 'switching' it at 1800 rpm, rather than infinitely variable as per Ford's ECU. For forest rallying, that's fine for me.
I thought the Zetec cams had smaller journals? Although I've never seen the two heads side by side to compare.
I'm looking at best options to increase CR, head worked and cams...which ones and from where I've no idea...open to suggestions.
Old 22-10-2013, 07:55 PM
  #204
The Underdog
you cant fix stupid
The Underdog's Avatar
im not an expert but from what iv read you will never get good power with the vvt coming in on a shift light setup, which sounds like what you have. lots of people do this and wate their time. your better off sticking to a bog standard engine. for ecu has a very complex way of working the vvt, its not On and Off. get it setup with a managment that can control it and you will see 195 to 200 on a standard engine max i think.
the man to speak to is will pedley racing.
Old 22-10-2013, 09:20 PM
  #205
R-A-J
R-A-J's Avatar
Hi there,
I'm running a standard ST170 on GSXR750 bodies, standard injectors and Canems ECU putting out 159 disappointing bhp in a Chevette and looking for around 225-240 useable brake. Could you possibly give me any tips, advice and costs?
what exhaust are you running and which model itb's are you running as the diameter will have an effect. Depending on this with good mapping you should be around the 200 mark so something is a miss somewhere. Do you have any power graphs with afr readings?
Old 22-10-2013, 09:22 PM
  #206
Timo.K
Timo.K's Avatar
For smooth road use that's very true, a switched VVT is a bit on the industrial side but for forest rallying it's been fine and the power curve on the rolling road was good..if not peaking a little lower than expected. As the inlet cam is fully advanced at peak revs, regardless of operation, it wouldn't make any difference to peak bhp..although may affect mid range torque slightly.
I'm interested in finding definitive information on ST head and cam mods which are proven to work..what bottom end mods need doing etc. The fueling and ignition I can find a happy compromise using my current set up later.
Old 22-10-2013, 09:29 PM
  #207
Timo.K
Timo.K's Avatar
Hi Raj,
I'm running a fairly simple set up with minimal inputs..Crank, tps, temps, only. No afm or air temp. sensors.
The length is approx 125mm, from trumpet to head, around 38mm chokes which should be about right. ST170 injectors which flow well up to 250bhp. Exhaust is a 4-2-1 with matched length primaries into a straight through 2 1/4" system with single rear free flowing box.
I've got the dyno readout but it's not really relevant as I want to upgrade the engine components anyway.
Old 22-10-2013, 09:31 PM
  #208
The Underdog
you cant fix stupid
contact will pedley i would. but a switched vvt has never made good power in any car iv researched. iv looked all over the web as i wanted to do it to mine and they all end up the same as yours. i know will pedley has the ecu and the knowledge to get the power you want.
Old 22-10-2013, 09:48 PM
  #209
R-A-J
R-A-J's Avatar
Hi Raj,
Hi Timo,
that's very similar to a spec crazycage and rick have done off here, they got around 200bhp, that was using megasquirt and some good mapping. Defo worth pm'ing either of them off here for their input. Thengine in question went like stink in a focus, now it lives in a fiesta mk2 shell
Old 22-10-2013, 10:49 PM
  #210
Timo.K
Timo.K's Avatar
Am I better off ditching the ST /VVT and going with a 2.0 Blacktop with cams?
Old 23-10-2013, 07:24 AM
  #211
R-A-J
R-A-J's Avatar
Best to speak to the person who is doing the mapping regarding ecu (should you wish to change) I would use VVT delete kit, the st170 is a much better base than a normal black top. The head is totally different especially in the inlet port size. I have had crazycage do some mild porting on my head and he said the inlets are fine as they are for my application.
There was a thread posted on here a while back with a link with someone who used a st170 head on a silvertop short motor I think, cams and a change in cr coupled with some other mods gave over 240bhp i think. It was an interesting thread.
Anyway dont want to hyjack daveboys thread might be worth starting a fresh thread as I know there would be a lot of input and interest in it
Old 25-10-2013, 08:07 AM
  #212
robrs2
robrs2's Avatar
Delete kit is the thing for the ST170. Done a mates and it far better now.
Old 25-10-2013, 08:40 AM
  #213
M K
M K's Avatar
Any progress with this Dave?
Old 25-10-2013, 10:04 AM
  #214
will@greenlight
will@greenlight's Avatar
this is possibly the most impressive build thread ive ever seen on any fiesta
Old 25-10-2013, 11:00 AM
  #215
Timo.K
Timo.K's Avatar
I've spoken to quite a few people so far and STILL not sure on what's best. Do I go for forged rods and piston kit to raise compression or skim the head/ deck the block and use standard ST170 bottom end? Which cams are best and with what engine mods for best torque giving circa 225 - 240 bhp?
Anyone actually done one who can give any definitive, reliable info?
Also, having done a little more research, the standard VVT seems to retard the inlet cam at higher revs so the 'switched' method may not be any good for ultimate bhp at higher revs, although the more important mid range torque seems ok..
Old 25-10-2013, 06:42 PM
  #216
The Underdog
you cant fix stupid
if you start a new post in general discussion i think that will be best because this is someones build thread specific for their car and its getting clogged up with other discussions.
id like to know more info so get one posted up.
Old 11-12-2013, 09:20 PM
  #217
Davey8oy
Davey8oy's Avatar
Little update here's few pics
New pedal box
Steering wheel wireless control
My central switch panel
New custom ap racing alloy belled discs and 4pot caliper
Oh And a set of road wheel
Old 11-12-2013, 09:41 PM
  #218
PaulinhoT
PaulinhoT's Avatar
Brilliant, all looking good
Old 11-12-2013, 09:42 PM
  #219
gus
gus's Avatar
Put them in the living room Dave.
Old 12-12-2013, 07:51 AM
  #220
smitsturbo
smitsturbo's Avatar
stunning
Old 12-12-2013, 08:42 AM
  #221
XRT_si
XRT_si's Avatar
Awesome, this is going to be something really special.
Shudder to think what it all cost though!
Old 12-12-2013, 08:56 AM
  #222
Fook me ive seen them wheels and ive got a hard on.
Old 12-12-2013, 10:16 AM
  #223
fatmat25
fatmat25's Avatar
i do believe this car is porn what colour you going for!!!!!
Old 12-12-2013, 12:40 PM
  #224
xr2john
Passionford Addict
xr2john's Avatar
That's an awesome build m8. Can't wait to see the finished results
Old 03-03-2014, 08:29 PM
  #225
little bram
little bram's Avatar
Any updates
Old 04-03-2014, 07:17 AM
  #226
sridgett
The only way is dagenham
sridgett's Avatar
Nice car mate. Gotta love a mk1 fiesta. Keep the pics coming.
LIFE'S SHORT SO FLOOR IT.
Old 08-07-2014, 08:38 PM
  #227
IanC
IanC's Avatar
Any updates on this yet? Special little car this
Old 09-07-2014, 12:38 PM
  #228
Davey8oy
Davey8oy's Avatar
Been really really busy with work but had few parts made for the mk1
Brakes
Oh and I've sold my 6 speed straight cut dog box and gone full sequential
Old 09-07-2014, 03:11 PM
  #229
bav
bav's Avatar
What an awesome build! Love it.
Old 09-07-2014, 10:18 PM
  #230
Miller 3
Miller 3's Avatar
Where did you get those brakes bud? And what size are they?
Old 10-07-2014, 11:20 AM
  #231
Davey8oy
Davey8oy's Avatar
reyland motorsport did all the brakes mate
Old 10-07-2014, 11:30 AM
  #232
XRT_si
XRT_si's Avatar
Good on you for doing the sequential, I know it's (very) expensive, but it will transform the way the car drives.
Old 10-07-2014, 11:45 AM
  #233
M K
M K's Avatar
Push push gears = AWESOME
Old 10-07-2014, 09:14 PM
  #234
marky_g
Fleet Manager
marky_g's Avatar
Wow this is amazing!
Old 11-07-2014, 10:11 PM
  #235
dough_man
dough_man's Avatar
This is awesome! Never seen so much power from an st 170.
Where did you get the belt tensioner from? The standard ones are crap.
Thanks
Old 30-09-2014, 06:59 PM
  #236
Davey8oy
Davey8oy's Avatar
Just a little update
Bought a ramp for my workshop to play with the mk1s instead of rolling around on the floor
Had a trip up to elite after I was a tad pi€%ed off with the waiting time for my box to go from 8 weeks to 3 month then to 6 months! So I collected my deposit and took a trip to quaife on the way home and picked this up
Also had a play with my Supersport over last couple of days fitted my coilovers and had the Ashley exhaust modded to fit closer to the body for more ground clearance
And got some more Carla cloth for the Supersport and the race car
Old 30-09-2014, 07:15 PM
  #237
XRT_si
XRT_si's Avatar
Very nice, what is the Quaife rated to?
Old 30-09-2014, 07:22 PM
  #238
M K
M K's Avatar
All that money and the box ain't even built up lol what a cheek
Old 30-09-2014, 07:52 PM
  #239
Davey8oy
Davey8oy's Avatar
Cheers mk lol
And the box is rated to 300 bhp
They have sold 30 kits so far to people using them for rally and circuit racing!
Old 01-10-2014, 07:21 AM
  #240
dug112y
passionford pro
dug112y's Avatar
Cheers mk lol
What price is the quaife and does it use std driveshafts or bolted flange shafts?
Quick Reply: ST170 mk1 fiesta crossmember update 2/9/15
