arch filled and painted
there was a small bit of bubbling between the teo panels in the rear arch drivers side, decided it needed to be done before things got worse.
grinded down, cleaned, treated and tipped back into shape
filled and feathered out
primed with 2k and ready for paint
basecoat
2 coats of high solid lacquer
basecoat
where the tape is at the top of the arch on the curve, are you going to wet and dry the join line out as i expect when you take that tape off there'll be an ever so slightly visable line between the new and old paint?
I'll rub it back with some compound by hand should do the trick, if not wet sand lightly with 3000 pad and compaound back up. I didn't lacquer all the way up to the soft edge tape just flicked it out with some fade out. Should be fine
yeah compounding will work, i only asked as i've done some DIY spraying before and i always get a join line between the old and new paint no matter how far away i put the masking tape so i always end up having to flat it back.
looks like a good job you did there though.
07-10-2015 12:56 PM
rsguy
44
29-09-2015 03:29 PM
SMILER258
28-09-2015 09:04 AM
