Muz's Escort RS Turbo Track Car. Bumper painted and fitted.
Old 05-04-2016, 10:23 PM
  #1161
turbotrev
turbotrev's Avatar
Looking awesome buddy, can't wait to see this in the flesh
Cheers Paul
Old 08-04-2016, 12:42 AM
  #1162
tockwell
tockwell's Avatar
Originally Posted by muz
Finished up the new switch gear panel today. Did it in a texture finish then also re did the monitor housing.
Utrinque paratus - indeed you certainly are!
I love the detail of the switches, this car is certainly my inspiration.
Old 09-04-2016, 03:49 PM
  #1163
muz
Wye Valley Hardcore
muz's Avatar
Cheers, lads, means a lot.
Done a bit on the throttle pedal set up. Admittedly, it's taken a lot longer than I planned due to having cut cut/make everything by hand. But it's starting to come together.
Took a tracing off the clutch pedal and made two identical sides from 3mm with a cut out for the balance bar cable.
Joined them with the 12mm ID pivot tube at the base and some 10mm bar at the top them put on a 2mm foot plate with identical dimensions to the clutch and brake pedals.
Then I had a think how to mount it and went a different direction to my original idea and came up with this.
In the car. It's obviously a bit on the piss as nothing's bolted down, but you get the idea. The pedal will also sit slightly higher when the mounts are added underneath the mounting plate.
H3lsing (09-04-2016)
Old 09-04-2016, 04:07 PM
  #1164
H3lsing
ffoc.co.uk
H3lsing's Avatar
Coming along nicely, that's quality fab work on the pedals you make it look easy.
Old 14-04-2016, 02:39 PM
  #1165
muz
Wye Valley Hardcore
muz's Avatar
Cheers, mate.
Just had a pic of the bumper from the painter.
The following 2 users liked this post by muz:
H3lsing (14-04-2016), turbo m (14-04-2016)
Old 15-04-2016, 09:32 PM
  #1166
muz
Wye Valley Hardcore
muz's Avatar
And fitted. Still need to play with the gaps etc, but looking good.
Old 15-04-2016, 09:45 PM
  #1167
jonfoc
jonfoc's Avatar
I tell you what Murray I was a bit sceptical about how it would look. It looks the nuts!
Old 15-04-2016, 10:04 PM
  #1168
muz
Wye Valley Hardcore
muz's Avatar
Everyone was... Including me, if I'm honest. I thought I'd ballsed it up and took it too far. Even my mate who painted it said "Fucking hell! That's going to look a bit Max Power!" When I dropped it off. When he called to say it was ready he said "fair play, it's mega"
Old 16-04-2016, 03:34 PM
  #1169
turbo m
turbo m's Avatar
As above, but now its painted and on looks great..
Old 19-04-2016, 06:17 PM
  #1170
muz
Wye Valley Hardcore
muz's Avatar
Decided matte black tanks etc in the engine bay are too hard to keep clean and nothing really stands out so a colour change is in order. Same matte grey the fuel system is painted in except with a texture undercoat.
Still need to do the oil catch can and boost and top water hose.
Old 19-04-2016, 10:48 PM
  #1171
Beach
Beach's Avatar
Looking great as always brother!!
Must update mine, each time i see this though its a hard act to follow keepinh the loyal fans happy.
Bumper looks great, takes serious balls, well played
Old 23-04-2016, 04:25 PM
  #1172
muz
Wye Valley Hardcore
muz's Avatar
Just a quick on of the new throttle. Still a few bits to finish like a throttle stop, torsion spring to return the pedal and tidy up a few bits but at least it works.
And a short vid of it working
http://smg.photobucket.com/user/murr...rlnsg.mp4.html
H3lsing (23-04-2016)
Old 21-05-2016, 06:27 PM
  #1173
muz
Wye Valley Hardcore
muz's Avatar
Finally got the throttle pedal squared. Just need cleaning now!
Also lots of arches...
I've always wanted S1 arches on it, but I really hate the S1 side skirts. I much prefer the S2 skirts. So I bought a set of smashed up S1 arches, and a spare set of S2 arches and this is happening...
Old 23-05-2016, 10:31 PM
  #1174
GINGExR2 T
GINGExR2 T's Avatar
Cracking work, love the arch idea.
Ginger
Old 23-05-2016, 11:01 PM
  #1175
fatboy billy
fatboy billy's Avatar
Can't wait to see the arches that mock up looks the nuts, I've always liked the s1 kit on a s2 but it's never been quite right but I think your going to nail it
Old 24-05-2016, 06:57 PM
  #1176
jonfoc
jonfoc's Avatar
That arch is looking good mate. Are you hoping you going to blend it to the sill or leave it "Motorsport "?
Old 24-05-2016, 07:54 PM
  #1177
muz
Wye Valley Hardcore
muz's Avatar
I initially tried to make it like an "over arch" to go on top of the standard ones but I'm going to blend it in now. Probably going to black rivet them on though.
Old 24-05-2016, 08:06 PM
  #1178
Nice one Muz
Old 27-05-2016, 07:41 AM
  #1179
The Underdog
you cant fix stupid
The Underdog's Avatar
Lovely looking car. What are the bonnet vents from?
Old 27-05-2016, 09:45 AM
  #1180
muz
Wye Valley Hardcore
muz's Avatar
The bonnet is half Mk4 Escort with a Lancia Delta Intergrale bonnet joined into it.
Old 27-05-2016, 02:42 PM
  #1181
The bonnet looks cool.
Old 27-05-2016, 03:44 PM
  #1182
The Underdog
you cant fix stupid
Very nice.
Old 04-07-2016, 05:51 PM
  #1183
muz
Wye Valley Hardcore
muz's Avatar
Not had much time on the car as the wife decided to give birth nearly a month early!
But a few little bits done. Rebuilt the driveshafts with new outer CV joints as one was a bit rough and fitted new hub bearings while it was all off the car.
I also had a slight raised area on the front discs from where a smaller calliper had been used so had the discs re-surfaced.
And while I was at it I had Lars knock up a replacement washer bottle in alloy.
Now all I need to do is paint it.
Car is hopefully off to Jano's over the weekend for a fettle, MOT then the road.
Old 05-07-2016, 08:20 AM
  #1184
james kiely
james kiely's Avatar
super detail mate
Old 11-07-2016, 05:05 PM
  #1185
gus
gus's Avatar
Let me know if you are down this way the weekend mate
I'm 15 minutes away from jano
Old 11-07-2016, 07:16 PM
  #1186
5hane
5hane's Avatar
That washer bottle is art,
looks awesome!!
Old 17-07-2016, 05:46 PM
  #1187
turbo m
turbo m's Avatar
Looks great in fast ford..
Old 17-07-2016, 11:14 PM
  #1188
boeb
boeb's Avatar
Going with this idea myself m8...am at drawing board stages on we're they sit on bumpers.am not liking the line change from arch to bumper ...did u smooth out the arch line that works into front bumper if u get me
Cracking build m8. car is a credit to the detailed work u have done
Old 19-07-2016, 10:04 PM
  #1189
windybob
windybob's Avatar
Give it some camber you'll have much more room for arch clearance.
Old 24-07-2016, 11:05 AM
  #1190
muz
Wye Valley Hardcore
muz's Avatar
I'll probably be about at some point this week, Gus.
Old 24-07-2016, 11:09 AM
  #1191
muz
Wye Valley Hardcore
muz's Avatar
looks awesome!!
Cheers, mate. Shame all the intricate bits are on the back!
Cheers. Can't wait to get a proper feature done master in the year.
I haven't done any more playing with them as the car is down at Jano's place. Will be doing some more to them next month.
It's already running slightly over 1.5degrees. Any more than that will have a negative effect on the handling. They don't touch the arches as they are, anyway. I just prefer the look of the S1 arches.
Old 24-07-2016, 11:11 AM
  #1192
muz
Wye Valley Hardcore
muz's Avatar
In the mean time, this has turned up.
Old 25-07-2016, 06:40 PM
  #1193
jonfoc
jonfoc's Avatar
Nice Murray. Genuine gartrac or copy?
Old 25-07-2016, 09:33 PM
  #1194
muz
Wye Valley Hardcore
muz's Avatar
It's a fibreglass copy bonded onto an original metal inner frame. Needs a bit of work but will be worth it.
Old 26-07-2016, 10:21 PM
  #1195
windybob
windybob's Avatar
These cars respond really well to - camber. I ran 6 degrees front and 3.5 rear on my XR Challenge escort and with the diff it handled fantastically.
Old 26-07-2016, 11:39 PM
  #1196
muz
Wye Valley Hardcore
muz's Avatar
Really?! Blimey, that's a lot. I've not heard of anyone running quite that much. Be interesting to see how much of an effect that much has.
Old 01-10-2016, 02:36 PM
  #1197
muz
Wye Valley Hardcore
muz's Avatar
Wide arches are on.
Old 01-10-2016, 03:36 PM
  #1198
xr2john
Passionford Addict
xr2john's Avatar
Looks awesome as always muz
Old 01-10-2016, 04:11 PM
  #1199
turbo m
turbo m's Avatar
Liking it a lot..
Old 01-10-2016, 10:02 PM
  #1200
tockwell
tockwell's Avatar
Muz, I love this car so much! What a wonderful progression. It is everything I like in a car.
Quick Reply: Muz's Escort RS Turbo Track Car. Bumper painted and fitted.
