my s2 to efi conversion update 04/06/06
decided to carry out this conversion cos i have had enough of the mfi system never being reliable i have decided to use a xr3i efi loom and sierra cvh cps parts i know some of u have proberly found a easy way of doing this but my loom has seen better days so i prefer to change it
iam wording everything as a bit of a simple guide for those who think this conversion is over complex and iam not a expert so if i make a mistake pls say
this i what i have done today engine loom removed and all mfi bits and pices
ok the cps system iam using consists of parts fom a 1800 cvh sierra they will need some adjustment i will post that when mine all fit
crank pully ,alternator pully,and alternator bracket
sierra cambelt cover this will be cut down to fit as i only need the bottom part to mount the cps
efi inlet manifold this one is from a 90 spec xr3i
coil pack and edis is also need ed for this conversion
ok update time
crank machined and rocker cover cut to fit
old loom out
crank pully fitted
xr3i efi loom almost fitted
cps fitted and connected up
coil pack fitted and it has a spark
sorry about the odd photo sizes i need more pratice
hopefully have a new update next weekend depending on parts arriving
old loom out
crank pully fitted
ok upadate time
sapcer plate arrived at last so i got the inlet manifold fitted bit of greif with the water pipes but got it done
and got my fuel pipe made and connected
hopefully will have it running as soon as the rocker cover arrives just a few more bits and it will be finished
mk3ste
17-10-2021 10:09 AM
Johnny Knoxville
30-09-2015 07:21 AM
SMILER258
28-09-2015 09:04 AM
