Fiesta MK2 resto.1.8 EFI now Running
#121
A few pics of where its living at the mo :blub: :blub:
A couple of engine pics too
Cleaned up the block and honed the bores
Installed the oil spray jets and bearings
Fitted the crank
Assembled the new pistons on to the rods
Installed the pistons
Installed the crank rear oil seal
Also my friend at the body shop fitted a oil return and oil temp sensor mount to my sump
Mart
Fitted the crank
Mart
#124
Im not planning anything :blub: Ive never managed to keep to the plan any way mainly due to money.
I will just keep plodding along with it and see what happens. Should be painted within a couple months now. Just need to do a few more foreigners to pay for the engine to be finished
Mart
Mart
#125
A couple more bodyshop pics
And on to some gearbox pics.
Ive opted for a Rear start IB5 with ST150 gear set and a ERST LSD. Dont know how well it will work, or even at all but we'll see.....
Stripped the MK5 Escort gearbox and ripped out the seals
Cleaned the box up inside and fitted new
Got the ST150 crown wheel machined by 2mm to the inside edge so it would fit the ERST diff and fitted it all together
Take note of how wide the crown wheel is compared to the BC type lol
Fitted the diff and selector mechanism in
followed by the gear set
and that is as far as Ive got but nearly there. Need to measure the axial play in the diff and set it up, but need to find out the measurment first
Mart
Mart
#126
It'll soon be out mate. . . nearly there
#133
Finally. . .
Should be built up for FordFair 2011 then?
#135
You know where I am when its time to build it back up. . .
#138
A couple more with a few bits on, now stuck in a corner waiting for the boot and other little bits to be painted. Going to leave the masking paper on the windows for now until the black surround has been done.
The painter who is doing it has gone on holiday for 2 weeks so need to wait a while again. I will just have to keep putting stuff on while its there.
Mart
Mart
#139
Oooooooooooooooooooooo looking good. . .
#141
Less than 3 weeks til Fordfair. Pull your finger out. . .
#143
Bet Kim can't wait to see it done?
It's been a long build mate. Nearly there.
You got a oil cooler for it? You'll need one.
#145
Get a gauge plumbed in.
#147
Paint updates???
#150
Looking good
#152
Nice. Needs black inserts in the bumpers.
#153
Told that to Niall today when we where talking about painting the kit
Wasnt 100% sure on the colour of the kit though, he thought it looked more grey but I think just black as per do handles and other plastic bits.. Dont want loads of different colours going on
#154
mate heres an idea, blank off the iscv port and fit a fiesta xr2i 8v iscv as they have the same plug and work the same but they can be relocated easily, i think some have it fitted to the manifold but others have a block with a pipe and the iscv is bolted to the airbox.
infact i have a whole setup in my shed but i need them for my throttle body conversion i am doing
#155
The fuel rail blocks the ISCV completely. I have drilled the manifold at the back and added a port for one side of a remote valve.For the other I'm going to use the original take off point for the fiesta valve on the crossover pipe. Hoping it will work factory like
Mart
#160
Ive got to paint all the kit before it can go on, its a bit of a mess at the minute
Need to do all the black parts (kit, mirrors,handles bumpers etc... Maybe intercooler to ) and then I can get it water tight ready to get it back to mine ready for a good clean up underneath and engine put in when its finished
Mart
Mart
