CVH to ZETEC conversion for under 200 quid-guide
#41
isn't it
To run one on carbs, you still need an engine managament loom to get the spark and it's correct timing. Edis alone will just give static 10degrees advance. It's easier to fit the converted loom and an injection tank and pump and get it running how it was intended rather than trying to use a 1300 spark map and carbs to get around fitting the proper ecu. Although with mappable ignition and a proper setup, twin carbs will provide good power. I do Megasquirt looms too btw which is what mine runs, with a turbo bolted on.
#42
isn't it
Well spurred on by this thread i now have a 2.0 Zetec with 1.8 bits already on, Like many stuck on the loom side thought i had it sorted then realised the engine loom i have bought has had some bits chopped off mainly edis plug , lamba wires and air sensor plug Not sure whether to cut plugs off a scrapper or get another loom ?
#43
Chief Iron Oxide Farmer.
Can you get away without fitting an injection tank simply by not letting the non-injection tank get too empty?
Or what about a small inline pot with a pump either side?
Given the rarity of XR3is (and any mk4 in fact) at a scrappy this may be an easier option.
#44
Its internal EDIS Pats loom with chip and key with mentioned plugs missing plan was to get it running then swap to a non PATS ecu so would need to change the ECU pins etc
#45
does anyone know if there is a wiring diagram anywhere on the net for this conversion, and a list of ALL parts that are reqired or need modified with pics
#47
good mate, i would like to add a couple of things though, firstly if you use the std escort mk5 zetec water pump hose then all you have to do is chop 3" out the middle and reconnect as the zetec rad is 3" higher than the cvh item.
secondly i didnt have to alter my top hose to fit, its the type with the sensor in too.
i believe its a rs turbo s2 top hose
#49
isn't it
Think you can get pattern tanks.
#50
Say you dont want the hassle of doing this yourself, is their any companys that offer this conversion as a drive in drive out??
With the 2 litre, i understand its better to fit a silver top version (earlier lump from a Mondeo) to avoid the sticking valves but is there any specific year / car to go for when using the 1.8 zetec version??
#52
orion=mini saff
bump
wiring side if this helps
grey/black,black to switched live
black and red is lambda live
green is rev counter
rest are constant live
brown is trigger for fuel pump!
use a ford yellow relay
u have 4 pins
85 to brown off loom
30 is perm live
86 is to switched live
89 to fuel pump!
u have 4 pins
30 is perm live
89 to fuel pump!
#59
wesskitzo
zetec conversion
hey mate just a quicky! i've transplanted the lump every things fitted engine wise. I ran the wiring as u showed behind dash up past fuse box, i know on the plug green/red-engine sensor red/black-lambda power black-ignition + injection power brown-earth! but wot do i tap them into at the mo they just sitting in engine bay? thanks wes wesskitzo@hotmail.com 07835612553
#60
now then, cracking write up but i'm a bit thick so i have a few question if you don't mind, please please.
first off i can get a 18 zetec from the brakers but he said its trom a R reg escort and the starter motor is at the back so i'm told, is this engine any good?
second, my car is a XR3i cab 1600 EFi do i still need to get a new tank
also how difficult is the wiring to do as my car is EFi as i am really poo with wires
ok so thats it for now and cheers in advance
Cheers, Chris
Cheers, Chris
#61
Cheers, Chris
Cheers, Chris
#63
help
hi there loving this thread just a few things what fuel tank are you useing and what down pipe are you useing and how long to do the whole job as want to put a zetec in my mk3 escort many thanks damian
#64
Cracking job, presumably the zetec flywheel/clutch just mates stright up??
- Looking to do simular on a rwd (type nine box) car and tryig to work out what i need for that.
Daniel
Daniel
#65
BTT need some more info on this please i have a mk5 base model 1.3 hcs what would i need and how would i wire loom in? Great help so far though just wiring that scares me,
i know i can use xr rs fuel tank and lines and an xr engine mount? and even radiator if neccesary, just want to know how to wire the loom in and cheers,
This should definately be stickied
#70
WTD:S1botom end&bodykit
Hi mate any chance of pm,ing me to help me with the wireing loom side of the conversion just afew quick questions ect..can ring you if you like would be really really great if you could cheeRs Dan
#75
hi guys was looking for a little help on this conversion. im looking to zetec my mk4 and use my rs turbo gear box. the prob i am having is the starter is on the front and i can only find zetecs with them on the back? any info on this?
also what engine would be best for me? 2.0? 1.8? from focus? mondeo?
loom ect not a prob as going to be running it on bike carbs with megajolt spark control.
cheeRs
scotty
cheeRs
scotty
#76
Nae Bither!
Hi there reading through you zetec guide there excellent stuff. I notice you say if you are using the 1800 you can you the flywheel and clutch from it aswell, only thing i was wondering is what thrust bearing do you use on the cvh clutch fork? cheers Ben.
#77
Great guide still going strong.
I gotta do this conversion on my track car soon, but i'm gonna use the whole original zetec loom from my donor car.
#79
Nae Bither!
Do you have a cvh or zetec box? As i had the 2.0 in my Escort last year and used the CVH flyweel and also just used rs turbo clutch kit. But now i'm using 1.8 flywheel and clutch, but didn't know if the zetec thrust bearing worked fine on the cvh clutch fork?
#80
My 1800i zetec lump in my MK2 Orion is running the 1800 zetec flywheel and clutch, with ERST gearbox and release bearing
Great conversion for the money
