Other Marques Use this section for any non Ford marques.
ford transit wont start problem
Old 09-07-2015, 05:11 AM
kieranricko06
kieranricko06's Avatar
Unhappy ford transit wont start problem
hi I have a 2002 ford transit 2.4di 90 t330 lwb 159.000miles drove spot on at first then driving it home on motorway at 60mph it started loosing power then changed down a gear but then I noticed it had cut out but hearing a noise like I was driving on a completely flat tyre for about 4seconds but my tyres were all fine when I checked pulled up on the hard shower and wont start turns over nicely but just wont start I have tried easy start jumps a little to try but still not starting tried to tow it still not starting was told by a few people it could be a fuel pump as there common but I don't know if it is that and if it was a fuel pump what other models will fit my van
ive..
checked all fuses tried tow start still nothink
tried easy start jumps a little but still no start
cracked an injector off and cranked it over was fuel coming out not sure of the pressure coming out as was only me around to check it
checked all wires and pipes
Old 09-07-2015, 04:53 PM
slammedorion
slammedorion's Avatar
Sounds like pump
Get codes read...
Refurbished pumps are £400 plus
Or buy 2nd hand and hope for the best...
You'll have to get it recoded too...
Old 10-07-2015, 03:51 AM
kieranricko06
fixed it today turned out to be the filter gauge ontop of the fuel filter head has a small crack at the back what was letting air in runs perfect now
Mark RS
14
11-08-2015 11:45 AM
Zoggon
10-08-2015 10:39 AM
vdubo7
02-08-2015 08:17 PM
Quick Reply: ford transit wont start problem
