Had my cossie on the rollers at the weekend...
#161
The gtx-r range has been out a while now though ain't they?
Some years at least I thought?
Cheers Paul
Cheers Paul
#163
If you took say a 7064 and a 9180, what exh housing do they come with as standard?
Or is it a choice when ordering the turbo? What housings are used on the yb for 500hp and 700hp respectively?
Cheers Paul
Cheers Paul
#164
The 7064 is the designation of the trim, I think....................... so you get the standard spec, you buy the 7064 if your limit is about 530bhp and 9180 if you want to go for 700 / 800 bhp
The next one up from my 7064 fits the same housing and will allow for 580bhp if I go for the 2.2 Ally block...this is Marks estimate and he is normally right on the money.
#165
Ever experienced a Borg Warner get core failure? Or you think they're reliable enough? Nice units, don't get me wrong.
#166
The GTX-R range is just out. Depending on the rear housing selection these are meant to be as good if not better. And more reliable? Or so I've heard.
On another note.. transmission loss is totally car dependent and what transmission you have. The Cosworth stuff from 30 years ago is archaic and will be no comparison to a GTR.
15-18% is about right for an average 4x4 system. The GTR will be much lower than that as it's a much better engineered system. FWD usually has the lowest transmission losses. Transverse mid-engined will be the same. Rear engined will also be similar like Porsche. But every car is different, that's my point.
My 1992 r32 gtr lost 30 hp per axle, r33 gtr just the same, 18 % is a load of pub talk nonsense imo
#167
Still car dependent
Rolling roads give a calculated and estimated flywheel figure. They are measuring from a rubber balloon on a wheel. I think it's been said already and in my opinion, hub dynos are a more accurate way of measuring power. After all, it's hard bolted.
#168
I have the revs already in the fact it will do that no problem, just wanna swap the turbo out for something like you said with a few othe small mods (exhaust and fuel system) then see.
Have you had a gt35?
What car did you gain the power on swapping the gt40 housings?
Cheers Paul
Cheers Paul
Similar plot to yours may have been in a little earlier, 1.6 bar boost 710 hp 8500 rpm it was a beast just needed lots of revs
Had screamer on aswell sounded awesome, I did manage a high 3s 0-60 but it was very hard on the car to do it lol
turbotrev (02-12-2016)
#170
Forgot about exhaust wheel failure on 9180 that we where deliberately over speeding and knowit could happen but 1000hp was sooo close lol.
Mark
#171
What I mean is they come with different exh housing options so for example would 500hp yb on a 7064 be on a .82 exh housing and say a 700hp yb like Mark Hudds be on something like a 1.05 housing?
Cheers Paul
#172
R33 gtr 1995 rb26 engine, gained over 100 hp from housing alone, i could tell from driving it that it was restricted and it was massivly
https://m.youtube.com/watch?v=v1lHP7Be0ro
Cheers Paul
#174
Ain't 7064 and 9180 the compressor and exhaust wheel diameter sizes in mm?
Cheers Paul
Cheers Paul
Mark
#175
When you go to post a reply, look at all the boxes on top of the text box, there's one that if you hover over it says Insert image, click on that and it will let you link an image directly from your computer so you don't have to go through the likes of photobucket.
#179
My gt40 was divided on divided manifold and it made a huge difference, I'm not saying Trev's will I don't know but it did on my rb26 mate a huge difference transformed the car
#183
Mark
#184
I didn't mean in reference to difference between twin scroll and open scroll mate, I ment housing size going bigger made a huge difference to my rb26 on the gt40, I remember we spoke about it at the time it really bought the motor to life
#187
Mark
#188
Not many trustable knowledgeable tuners out there like you mark
#189
Mine wasn't it was divided turbo gt40, divided hks I think manifold just divided between 3 and 4, I don't think the screamer was divided though, the only point I was trying to make is IF your turbine housing is to small it will make a huge difference to power, I've not had a gt30 on a yb so I don't know where the limits are for yours, il add pics in abit if I can
#190
Sponsor
#191
here you go trev
rb26, worked head, stage 2 cams, gt40 o.85 ar
I wasn't happy it was making the numbers it should and it wasn't as fast as I expected it to be it felt like 600 hp because that's all it was
so when mark confirmed theres a good chance it will help, I went straight to a 1.06ar, I did drive it after fitting housing could instantly feel the difference and was way lean as soon as I got on boost on my wideband, so I got it mapped of hub dyno at same boost
dyno showed over 100 hp extra, and that was confirmed with my 30-130 mph times, and 1/4 mile mph went from iirc 123 mph upto 129 mph
and I only lost 300 rpm, it just felt so much better, the only difference I noticed was harder making boost of the line, once in gear moving it was much better, I was in the middle of sorting some boost build launch control on hks gear but then I had diff and 4wd issues and bought the r35 so the r33 got broke up for parts.
turbotrev (03-12-2016)
scoooby slayer (02-12-2016)
#198
#200
Mark
