OFAM Expert needed.
OFAM Expert needed.
Hi,
recently got an ofam ecu but im having a few problem i could do with someone helping me.
i cant get it to idle and the afr gauge doesnt work along side the tunerstudio interface..
Is there any local, WEST MIDLANDS megasquirt tuners that could come to me and advise me on what is wrong.
spec of the engine is
2.1zvh
fardon rods
standard cam
standard t3
beige injectors
Currently running it on ofab with 195 chip but it isnt right and my incar afr says its over 16.5 so its running lean on that set up..
My eyes and ears are open awaiting help.
thanks
2.1zvh
fardon rods
standard cam
standard t3
beige injectors
thanks
Never had ofam but can tell you when I was running my 2.1 zvh before I bought my pectel management I was running ofab on a 195 chip and was under fueling bad so I bought some st170 injectors for a £10er of eBay and went back to the rollers and they said it was much better, not perfect but was safe enough for 12psi at the time.... Tuners words was its fueling like a scooby on full chat, idle and half throttle was near spot on... Hope this helps till you can sort the ofam out properly
Unstablecable
02-04-2016 06:58 PM
Farooq
17-03-2016 09:29 PM
