Cosworth Crank Sensors ?
RWD Racer
Am looking for 2 new Ford Cosworth 2 pin crank sensors as part of a ignition trigger kit for an RB engine. From what I've seen the prices range from £16 to £30 give or take. But are the sensors all as good as each other, or would it be wise to spend the extra and go for the dearer sensors ?
Are they all as good or ???
RWD Racer
Yes chap, Sorry Nissan RB engine but using cossie crank sensors as part of an ignition setup to do away with the oe cam sensor (dizzy)
Should just be able to see on the exh cam wheel, the other being on the crank much the same as a cossie set up
stevos (26-05-2016)
cossie09
11
26-03-2016 06:32 PM
