Internal or External wastegate whats best
So based on using a BW EFR turbo as that's what I want next what's best and why internally or externally gated.
How is the external gate controlled and dose this require a aftermarket ECU to do it properly.
Depends how much boost, power, range of boost etc etc
Generally external is preferable, but not always essential
Control is no different whether internal or external.
boost control will definatley be better but space and heat management can be an issue sometimes
You can do external gate on pretty much any ecu for safety I usually run a soft spring and use boost to keep the gate closed so if the solenoid or hoses fail the boost goes down
Indyrs
27-11-2015 03:29 PM
cossie09
25-11-2015 08:27 PM
