r33 gtr 710 hp new performance results in 30 - 130 smashed page 10
#121
no mate i havnt, to be honest i didnt think about, i havnt really driven it at all yet though tbh, i need some time in it to get used to it the clutch and shifts are different and i was struggling with it abit the few goes ive had in it, i will be at pod this year though at least for some rwyb.
Rich
#124
well the hunt for 700+whp again has begun
i want to get abit closer to the power the supra had.
my manifold is layed out in twin scroll but it doesnt have equal length runners and it only has 1 wastegate that joins both sides just below the t4 flange so not true twin scroll but i think i am going to try it as the gt40 was spooling well even with the manifold blowing badly so it can only get better my dyno graph shows 1 bar by 4200 rpm.
after reading mad ades thread about these borg warner turbos i am going to treat myself to an efr 9180 with a t4 1.05 a/r external wastegate turbine housing. i have had a quick measure and im sure the turbo will sit on my manifold ok and not foul anywhere, i can just mod my downpipe to suit if necasary and my oil and water lines.
i am hopeful it will spool like my gt40 does on its 0.84 a/r housing but make 100+ whp more up top at around 1.5 bar and a bit more torque aswell, and pick up better after shifting.
ive just gotta find one now as stocks seem very limited.
#127
at all 4 hubs its makeing 590 hp, so about 660 flywheel hp, 475 lb ft flywheel. 1 bar of boost 4250 rpm, and the full 1.5 - 1.6 bar by 4600 rpm.
but if i was you id be looking at the new bw efr series maybe the 8374 or what im going for the t4 twin scroll 9180.
#128
welll i took the old girl for mot yesterday afternoon straight through no advisorys.
il tax it 1st of march.
i went for a quick run before i came home as i havnt driven it since refitting the manifold now its all done properly, so i did a few runs in 3rd gear and i hit 0.5 bar boost at exactly 3500 rpm and all in 1.5 bar by roughly 4600 rpm its hard to say exactly as once the boost passes 0.5 bar the revs rise so quickly its a job to watch it tbh.
so with no alterations to the boost controller ive gone from holding 1.3 bar in 4th gear to holding 1.5 bar in 3rd gear, 4th gear should now see nearer 1.6 bar id of thought with the extra load of the taller gear.
response is vastly improved aswell the manifold leak was far worse than i had realised tbh and with me running the small exhaust housing there must be alot of back pressure in the manifold trying to get out anywhere it can.
im in no rush to change to an efr9180 now as it feels so much better now im not sure it needs it, im gonna just use it as is now for a while and see how i go.
il get the racelogic out soon and see how things have imrpoved with the extra boost and response.
happy days
happy days
#129
well the max i can see in any gear is 1.5 bar, it is responsive for such a big turbo but still only running 650 hp from a gt40 seems pointless when a gt35 should do that, so ive ordered this and it came today.
a 1.06 exhaust housing as i think my 0.85 a/r ts housing is causing a restriction, im hopeing once mapped i will be able to run nearer 2 bar boost with the new housing
the car has (apparantly) run 875 hp in japan so im hopeing the engine has some more to give.
#131
non billet, it was purchased august 2008 by previous owner but has only done 4000 miles since at max 1.5 bar.
i think the 1.6 bar on the dynapack run is just due to being run at more load than i can make on the road.
#135
Same housing I had on the ybt will make more power higher up the revs mine was capped at 8800 rpm but was still pulling on the graph but was only 2litre,yours will make shit loads more torque with more boost but obviously you may loose 500 to 700 rpm before it hits full boost
#136
tbh i hadnt thought of that, il make sure i get some perfect runs in with the v box before i switch the housing out and remap.
excellent thats nice to know mate, i dont really wana go beyond 8000 rpm but even so im currently making 1 bar by 4250 rpm and 1.5 bar 4600 rpm so if i end up with 5000 - 8000 rpm useable power band i can live with that.
it is quite strange at the moment it is super responsive and comes on boost but although the boost is there it doesnt seem to pull then i feel it pull again at around 5000 rpm, i think with the 0.85 a/r housing its almost trying to boost to soon and the engine cant use all the air, i think if it didnt have the anti surge housing it would be surgeing tbh.
although i love the responsiveness im running a gt4094R at 650 hp which seems pointless i could have a gt35 doing that i should be nearer 750 hp hopefully.
the 0.85 a/r twin scroll on my 2700cc six pot i think is a big restriction and hindering the top end power and the ammount of boost i can run.
just from my exhaust leaks ive gained 0.2 bar of boost and the leaks wernt massive it says to me theres a hell of a lot of back pressure in the manifold.
mark shead said to me the 1.06 a/r housing was the one to go for with my turbo so i bought one, she should be manic at 2 bar boost hopefully
where did you make full boost on a 1.06 a/r mate ?
#137
Never had a single setup on my r34 gtr had twin hks but was a 2.8 hks motor ,still used to pull to 8000rpm where the limiter was set,and the best It ran was 11.3
#139
#140
ive found these on ebay
http://www.ebay.co.uk/itm/Snail-Turb...item1e7867fa10
thats for a gt3582r but they do sell one for my turbo for about Ł220, i wonder if there any good and how much id gain ? is it just the comp wheel thats different on the gtx turbos do you know ? do they add spool time for more power ?
im only on 99 fuel and not sure on exact head/cams spec, if i could get full boost by 5200 rpm on my 2700cc id be happy with that.
#142
is the porsche on a gt4094r jimbo ? and if thats on your engine dyno aswell its not really comparable as the engine is under more load isnt it ?
how is the load calculated on an engine dyno ?
i have the exact ramp time data for my dyno plot on the 0.84 a/r housing.
im currently makeing 654 bhp at 7500 rpm and boost at that point was 1.5 bar. right in the middle of the curve at 4500 rpm 300 hub power, 400 lbft. the ramp rate was set at 300 rpm per second.
i dont want to even try to run more boost with my housing as im sure the little twin scroll 0.85 a/r housing is on its knees already.
have you seen any engines on your dyno with a twin scroll 0.85 ar housing by any chance mate ?
im hopeing with the bigger housing i can run around 2 bar of boost, hopefully gaining 100 lbft and 100 hp, either way with a more freely flowing turbo and 7 psi more boost its gotta make more power, its running twin fuel pumps and 1000cc injectors so ive got plenty of fuelling scope left and its been converted to map sensor seen 1.7 bar peak on dyno plot so should be a 3 bar map in there aswell.
#143
jimbo the skylines aren't normally laggy but the ones I've allways had have been on twins so spool was fantastic as you say so was the torque,my escort was laggy but was on a 1.06 ex housing so power range was 5200 to 8800 ,but obviously not user friendly round the town,must of had a descent size turbo on the 944,sounds a good result though
#144
B1mbo
The porsche was run on lots of different turbos from one off made to a straight forward t04z which is 72lb air and we only ran 1.9bar
The t04z is a very close match for the gt40
And that was a first attempt with what cams we were given, anyway power output wasn't my aim I just wanted to see why in general the single turbo skylines never seem to work down the bottom,
#145
B1mbo
#146
Although obviously depending on who built it or what spec, it could be a combination of all sorts.
I'm sure there are some turbos out there still using the old turbine wheels but with new billet compressor wheels.
An example of Precisions older turbine vs their newer stuff. The new wheel being much lighter.
#147
do you know what housing the porsche was on mate ?
#148
The latest "billet" turbos use different compressor wheels as well as lighter and more efficient turbine wheels.
the snail advertised wheels seem to be a drop in replacement im just gonna look around and see what the gains/losses are.
#149
The Snail wheels do look like a possibility, but then the unit will need balanced etc and of course you need to find someone happy enough to fit the wheels which have nothing to do with them ( read warranty and customer backlash if things go wrong )
How much actual technical engineering is in their wheels as opposed to others, Ive no idea. Are they just mirroring cast wheels on their CNC ? material quality etc ?
I actually inquired with them about making a new wheel for my supercharger. But they were a very new seller on egay then, and the thought of sending my parts to Taiwan, was just a bit too risky. But of all the places I emailed, they were by far the most helpful.
Extreme Tuners in Greece seem to have a huge range, although despite saying they could make me one...when it actually came to pricing or lead times, they stopped emailing.
#151
#152
struggling with reality
you said "if only nissan had used cat studs 3/8 unc they would never snap there tough old bolts"
well we had so many problems when removing the exhaust manifold on my toy we decided to replace them with items that would resist corrosion much better! we thought about going all titanium but would have had problems with the titanium studs so went for a more corrosion resistant steel and high temp titanium locking nuts. It is worth the aggravation!
#153
B1mbo
For a comparison at 2.05 bar big valve 2.2yb on pump give 711 so the Porsche is even to the yb there abouts except it's 500cc up so not quite as efficient
Why does it sound alot, that turbo on race fuel can show 780/790 at 34psi
Ps I'll get the exact figure from tim as I'm going by memory
Pps the .82 exhaust housing is obviously more than capable and suited to the exhaust wheel to be 10psi down on back pressure in relation to boost
#154
Yes bench dyno, five inch exhaust 15deg ign
#156
im gonna see if i can find any tests been done with them now ......
#157
ive been doing a quick bit of math.
the gt4094r is rated at 800 hp max so im assumeing it would take the biggest housing 1.19 ar to achieve that power so as to allow the engine to flow enough exhasust gas.
now the 1.19 ar housing flows 37 lb/min of air meaning for every 1 lb/min of flow it can produce a maximum of 21.6 hp.
my current housing is a 0.85 a/r rated at 31.5 lb/min so should see 680 hp but i actually made 654 hp so 26 hp down.
now useing the same math im now fitting a 1.06 ar housing at 35 lb/min so max it should flow is 756 hp, the if i loose the same 26 hp in theory i should see around 730 hp.
wether it will work out like that remains to be seen lol
#160
well its reported as having 268/272 cams and having made 875 hp in japan on a t88 34d.
its holding 1.5 bar no problems and must have massive backpressure at that im sure, i know of someone who tested a 3.0 on a 0.95 a/r housing and backpressure limited boost to 1.5 bar !
im hopeful to get it mapped at 2 bar boost and still have less pressure than its currently got, fingers crossed it holds together, the current setup has done 4k miles with some track days in it so hopefully any issues would of shown themselves by now.
1.05 back pressure slightly worse ! imagine how bad my 0.85 is lol
im hopeing i wont loose as much spool as im thinking i will as it may be just getting rid of a bottleneck lower in the rpms aswell hopefully.
