HELP!! Megajolt/ Megaspark thingies? where from?
big floppy donkey dick
i am desperate for one of those megajolt or megaspark stand alone box thingies, did the usual interweb searches but found no prices or dealers UK or US, anyone run this? please help!
im not after megasquirt as my zetec will be on carbs when i need the spark box jobbie.
please help?!
regards Sean.
please help?!
regards Sean.
It's mainly DIY, but I did think there were a couple of people doing kits? (maybe just the ms system)
http://picasso.org/mjlj/
http://www.cate1.co.uk/megajolt/index.php
http://www.bgsoflex.com/mjl/mjl_edis.html
Sean, Megajolt is the one for ignition only but it is limited.
Megasquirt is the one to go for as it will allow you to do much more. If you ever wanted to run NOS it will run that too just one example.
What crank sensor will you be running ?
If you have the 36-1 toothed wheel then the V3 board is the Megasquirt to use with the Megasquirt 1 processor chip.
In kit form its Ł165 and built its about Ł50 more. If you order one from the USA watch out I got and nice bill from customs for the extra VAT
I'll PM you the lads that build them over here.
Matt J
29-07-2004 06:08 PM
