AS Cosworth Breather 4x4
Does anyone run the Autospecialist breather on their 4x4 cosworth?
ive got 16mm hose ran from either side of block and a 10mm hose from the factory sump return. Anyone running this setup? it says on the site that the pipework required is 16mm but wanted to check the return is 10mm or close enough
http://www.autospecialists.co.uk/Pro...oduct-756.html
