Rotating them does help, but the issues are that the rubber o-ring stops being rubber and that hold them in situ
I found that turning then first so that there was the possibility to get a small screwdriver underneath the lip, then squirting some WD40 into the gap normally did the truck
Don't forget that too much lube inside will ruin the grade for the bearings
