coilover clunking
coilover clunking
I have just fitted some gaz golds to the sierra , backs went on fine apart from I had to bash the inner wing but the fronts are clunking as the springs is moving when I turn the steering wheel left to right.
any one else have this problem ??
Top bearing?
I put the bearing on top of the spring cup , then the nut then the bottom half off the strut top then fitted it onto the car then the strut top then new bolt that came with the gaz coilovers
