ALS in L8?
Yes, so do I,
although I found that the iscv - throttle body modification was not very effective, and went for a remote bosch idle valve together with the other mods
It is quite simple actually, but the level of agression you want makes it complicated
1. A chip that supports it. (I use an MSD chip)
2. Switch to ground an ECU pin (on the original plug that controls the ignition timing)
3. ISCV valve modification / throttle body bypass vent enlarging
and optional
4. larger remote ISCV valve
I have a modified throttle body, modified ISCV (not the top hat type) and a secondary valve. The largest boost pressure I have seen is 0.4 bar when off throttle
and optional
Stavros
23-12-2004 07:14 PM
RickDraper
12
26-06-2004 11:50 PM
