what's involved in putting a zetec into....
A sierra with either a Cvh/pinto or twinkly please.
I know the pinto uses spacers on the Xmember to lower it so I mates with the type9.
Just wondered what engine mounts & arms etc are required to mate a zetec to a mt75 if you would be so kind.
Also what management, or are carbs a better option. I've got something in my head I might do. Cheapest options please.
Chris
Chris
use the sump, pick up pipe, engine mounts off a 1.8 cvh. starter motor off a 2.0 dohc Granada auto .zetec flywheel needs redowling to take pinto clutch. that's the basics to get it in.
I used carbs and an after market ecu. theres plenty of options with induction and wiring.
Ben
Simplest in terms of getting it running would be a set of bike carbs and Megajolt ECU, I've still got the ECU kicking around someone if you're interested.
kyle_st200
Ford Focus Diesel
21-08-2015 09:28 PM
