Saff cosworth base CO won't adjust
Old 04-04-2014, 05:30 PM
p1nky87
p1nky87's Avatar
Default Saff cosworth base CO won't adjust
Hi, new to passion ford... As above, my base CO insists on staying at 10% when I adjust the screw. Has a new MSD chip, greens, 3bar etc... Help?
Old 12-04-2014, 10:09 AM
boostn_capri
boostn_capri's Avatar
Hey mate, have you checked the screw that you are turning is making contact with the actual dial within the ecu? theres a post on here somewhere saying to not push to hard on the screw when adjusting.You could check by taking cover off ecu and making sure its all connected.
Old 19-04-2014, 09:06 AM
nixon_2wd
nixon_2wd's Avatar
As above, check to see if its loose inside. They can be "overturned" quite easily.
jessie_rs
11
03-06-2019 04:57 PM
Anutternutter
24
31-08-2015 01:24 PM
Anutternutter
21-08-2015 06:07 PM
James Porter
14-08-2015 12:43 PM
14-08-2015 07:29 AM
Quick Reply: Saff cosworth base CO won't adjust
