is removing pedal box easy?
Resident Wrestling Legend
it's very easy
there are 3 nuts that hold it in place plus a bolt hidden away up top somewhere
just use a long extension and make sure you have a torch
just be aware that the pedal box also holds the abs stuff on the other side of the bulkhead, so you only need to to the top right and both bottom nuts, the top left one "should" be just sitting there doing nothing but holding the abs in place
also it's easier to remove the clutch cable by pressing the pedal and then jamming a screw driver into the fork so that it's just as easy to put back in again afterwards
mine collapsed years ago and i spent money on a new clutch before i figured out it was the box
track.focus'd
12-08-2015 05:53 PM
