Compression ratios
Compression ratios
If I have a 4x4 Cossie YB 200 block with a 0.5 overbore, Valve pocketed pistons, block decked (minimum to fit wrc gasket) and a head with 137.56mm thickness, what compression ratio will I be running?
Regards, Kieren
Regards, Kieren
