cosworth piston fitting problem (rings)
ive got a slight problem, ive got standard size cylinders on a 205 block standard size pistons and new standard size mahle piston rings fitted yet they will not go into the cylinders atall, had a mate round whos built plenty of engines and all he can think is i need a better piston ring compressor? both of us are baffled by it has anyone else ever had this problem or know what else i should try other then a different piston ring compressor?
PassionFords Creator
- Install rings into bore and set ring gaps if required.
- Install rings onto pistons and ensure the same ring gap can be attained, thus proving piston grooves are correct
- Install into bores.
If step 2 fails... Piston is wrong for ring and maybe bore.
The installation is the simple bit! Clamp them up until ring gap is virtually (NOT totally) removed then slot them in!
Step 1 and 2 passing as fine guarantees that step 3 is possible.
all sorted now thanks for the advice took all the rings off for a double check, bottom ring on 1 piston needed a slight trim all in now and sorted
Zoggon
10-08-2015 10:39 AM
