Help in removing the hand brake cables from the calipers
Hi All
is there a special way in removing the hand brake cables from the rear calipers? I am having so much trouble it is driving me wild.
Any help or insight would be very favourable.
Thanks for reading
Andrew
Thanks for reading
Andrew
As said, you need to slacken the cables, the adjustment is not done from the lever itself though!
There are two plastic nuts on the cable itself (Passenger side towards rear), ones a locking nut and the other is the actual adjuster nut, you need to loosen this so you can gain some slack in the cable.
Martin
Martin
track.focus'd
12-08-2015 05:53 PM
