Fueltank
Outlet pipe for the fuel pump should also be bigger on the Cossie one.
Just bought one of these:
http://www.ebay.de/itm/120913958136?...#ht_500wt_1156
Live long and prosper!!
So does the xr4i they are the same tank all with a 15mm o/d outlet 8mm o/d return
Dohc tanks have and intank pump inside a collector but can be used on a cossie with and uprated pump from a escort cossie fitted( if needed ) but will require re plumbing and re wiring
If you want to see a cossie swirl pot i can get a pic as i cut one up to fit into another tank
thanks for the order....tank has been dispatched and on its way
atm
29-09-2012 02:25 PM
rsturbo27
05-08-2011 08:35 PM
cozzie4d
11-05-2006 11:27 AM
