krypton tune! any point
hi guys got my car back on the road after 11yrs last week, however the emissions were mega, I have taken the plugs out and they are black the car is missing and coughing and spluttering like mad and stinking of fuel.
Im too afraid to drive it anywhere in case it breaks down, he comes my question
Is it worth me getting out a mobile tuning to give it a set up or should i try and get it to the nearest rollers to get it checked out?
Or are these mobile guys a waste of time and money
any advice appreciated
thanks
Paul
thanks
Paul
It entirely depends on the car you have, as said? If servicing has been neglected, then it's worth giving it a full service first, before you even think of getting it tuned.
Edit: Just spotted the forum it's in, makes it kind of obvious lol, assuming it's a non Cosworth, what model/engine is it?
Martin
Martin
Martin
Martin
The reason i thought of a mobile guy is to try and get the emissions down so the car would run ok hopefully
Any ideas would be great as im scratching my head now as im stumped
thanks again
Paul
First thing I would be doing is replacing the CTS, this sensor is at the back left hand side of the head, it's a bit tight to get to, this is likely to be a cause of the problem, and if not it's worth replacing it anyway.
This, essentially, is a thermistor and tells the ECU the temperature of the coolant, this is an input which will determine the base level of fuel injected from freezing to boiling.
Over time though, being a resistor the output on these can go out of range, hence telling the ECU duff info, leading to your overfuelling.
Personally, if it were me I woulden't use a Krypton tune, I would use a specialist for a 'setup'.
Martin
Martin
SMILER258
28-09-2015 09:04 AM
